Post Info TOPIC: Water Filling Station
Hi all, the water filling stations I have seen over the last few days have a 25mm hose as the smallest filling point. So far the hoses dont have an end fitting at all , I gather to supply buik water to a tank. Has anyone used these with a suitable fitting to fill directly into van tanks? I cant seem to find a removable fitting for the end of the hose that I could easily attach to use, then detached when finished, or is this not possible for these types of filling stations? Thank you.
We use a 250mm long piece of clear pvc tubing with female hose adaptor fitted. We use our own Blue hoses when filling up our tanks.
If the hose I was getting water from hasn't got a fitting, I would purchase a cheap plastic set of hose fittings from $2 shop, you can either donate it to the hose or quickly unscrew.
Thanks Possum.
