Post Info TOPIC: Reprogramming lights - Conquest RV 2019
I accidentally pushed a light switch and the off switch at the same time, which has now cancelled out the on / off of the original light switches to 80% of interior lights.
I remember having to reprogram our last Jayco RV Optimum Under similar circumstances,
I cannot find any written documentation regarding how to do it, can anybody help me with this please?
Fumble fingers Campo
I can't help with your dilemma Campo but, welcome to the Forum.
Assuming the wireless controller is the same as the one in our Journey DX there are  series of numbered reset buttons on the controller-under the seat in battery compartment. Each number relates to a particular switch. Trial and error initially but with an observer watching the light/switches should be OK. If this doesn't jog the memory I suggest that you call your nearest Jayco dealer and ask for advice-you may wish to be at the controller as they talk you through.
Thank you in the forum for your kind welcoming.
Google Sphere 6 channel receiver
It should take you to Rvparts express .com.au
Then select the download
Should be good to cheers Gerry
If you have a constant red light on a channel, post here
and i will put the remedy up.
Don't assume that the
gizmo is broken. they are quite durable but all the
connecting/unconnecting switching etc etc in a hotch-
potch of wiring that is characteristic of a van can cause
blips on these devices.
Especially connecting/reconnecting battery in wrong
order with loads operating.
B
-- Edited by Brodie Allen on Thursday 25th of January 2024 07:50:30 PM
-- Edited by Brodie Allen on Thursday 25th of January 2024 07:51:43 PM
Mistake above for fixing the channel lights. First line should read GREEN light not red.
For some reason cannot edit.
