Post Info TOPIC: Hi we have a 2011 starcraft
Hi we have a starcraft caravan and the light over the bed is flashing so needs replacing with an LED globe. The glass tube around the light does not move so cannot get at the led. Could anyone who has had this problem contact me with the answer,
A pic of the light fitting may get you a better response, lots of vans use the same fittings but most of us do not own the same van as you.
From deep in my memory, its either turn the cover or look closely at the there maybe a small flat hole that you can insert a blade screw driver in to to release the cover from the mounting block access the globe removal.
