Post Info TOPIC: Dometic Harrier compressor mount dimensions.
Wondering if anyone has the dimensions of the compressor mounts for a Harrier a/c unit.
Arald and Desleigh
Theres more to life than work.
Keep Dreamin!!
Specifications:
Electrical rating: 220 to 240 V
Compressor Capacity: 3600W
Cooling Capacity: 543W to 3218W
Heating Capacity: 512W to 3195W
Current Draw: 1.8A to 7.9A / 1.7A to 6.8A
Operating Temperature Range: -2 to 52°C
Airflow: 649m3/h (maximum)
External Dimensions: 750 x 280 x 1070mm (WxHxL)
Internal Dimensions: 518 x 48 x 579mm (WxHxL)
Roof Opening: 360 x 360mm or 400 x 400mm
Roof Thickness: 30-100mm
Weight: 44kg
Fan Speeds: 4 speeds including Turbo
Net Weight: 44kg
Best For Vehicles: Up to 7.5m
Manufacturer's Warranty: 3yr Dometic Warranty
_________________________________________________________________________
Ipso Facto you would need a solid area (Frame) mount area the difference between external and internal dimensions.
 Caravans plus have spare compressor available, they haven't published a mount dimension drawing but perhaps if you send them an email they may measure it for you. No phone contact available..
Chris & Sharyn.
Tea Gardens. NSW.
Thanks. Will try them
Arald and Desleigh
Keep Dreamin!!
Thanks
Arald and Desleigh
Keep Dreamin!!
