Post Info TOPIC: Best uhf radio
Best uhf radio
Could someone suggest the best uhf radio
That piece of string is four times the standard length!
For vehicle or person?
External aerial?
 Welcome to the forum Ian.Others may have lots of complicated technical advice but I've always had good results with GME, in both the Roadtrain and in my car in the back of beyond. Good luck with your search! Cheers
P.S Make sure that you get an aerial that is appropriate for your intended usage patterns.
P.S Have a couple of 5 watt GME handhelds, but not used yet!
-- Edited by yobarr on Thursday 10th of August 2023 06:18:32 PM
Welcome to the Forum Ian. Radio not my forte' - I use Uniden base station and GME handhelds - Works with sufficient range for needs.
I have a very good Oricom unit which has proven to be very reliable and pretty good range. Australian company too if that matters to you. Bought a kit which included the aerial. Price was pretty reasonable too.
Greg O'Brien
Everyone I know who has a 5Watt fixed UHF unit in their vehicle is happy with their purchase. I am happy with my $129.00 Oricom. A decent antenna helps. Also, I have a 5Watt hand held no brand that I use in the caravan. If you want heaps of options and accessories you will pay much more. Standard features seems to satisfy most users.
Cheers, Richard (Dick0)
Icom - Japanese built quality & ruggedness. Used extensively on outback stations where thy are an everyday tool. Cost a little more than most but worth every cent if you want lifetime quality. In car & handheld. Once you have owned & used one you wont choose anything else.
www.icom-australia.com/products-uhf.html
A Nomadic Life (Current)
The Big Trip (2008/9)
When l upgraded from my old 40 UHF l brought a GME because it fit perfectly into a space in my dash. It has served me well for 8 years now.
Home is where I park the rig.
Tug 2016 D-Maxine
Den 2009 Goldie RV
