Post Info TOPIC: Kingjack TV aerial attentuator
This used to show blue lights when TV powered up and attenuator switched to ON On checking I cannot get the blue lights . there is an electronic box on pulling the unit apart Does anyone know how to replace the electronic box or do I need to buy a complete new unit ? Thanks
Phil
Hi Phil, I was puzzled by your heading Kingjack TV aerial attenuator. Possibly the "attenuator" is incorrect and you might mean booster or something else. Maybe that is why no one has replied.
Here is a link to the Kingjack site;  https://kingconnect.com/
Hi, the thing with blue lights is simply there to check signal strength as you rotate the aerial inside the van
Phil
This is the inside view, the light array no longer works
Phil
So I have solved this problem. Ripped out old TV and installed a $380 Smart TV (bought it on line from the shop with a capital A ) By using personal hotspot from iPhone ( Telstra gives me one or two bars where I live ) I can then load various apps like SBS on demand and ABC iview. Netflix account also OK with great reception. This is more than enough for our needs and TV aerial problem is no longer an issue
Phil
