Post Info TOPIC: Removing pop rivets.
A step drill is the way to go. Its taken me far to long to learn this trick.
Be aware that; if using a "step drill" to remove pop rivets that the resultant hole will no longer be suitable to replace pop rivets, as you will enlarge the hole - it is better to use a twist drill sized similar to the correct size of drill required for initially fitting the rivets.
The removed rivet flange will feed onto the drill bit, like a "collar" which can be removed from bit with pliers. Bit fussy but better job not damaging the original surface.
Im not having any problems replacing the rivets.
You only need to drill the the top off and punch them out ..Or use same size drill on hammer .
Always did it that way. Drill the collar off and you are ready to re-rivet.
Cheers, Richard (Dick0)
Or 1/8 drill for normal small rivet ?
