Post Info TOPIC: Domestic cts4110 toilet keep running
Hi All I have a dometic cts4110 toilet that keeps overflowing. when I flush it works fine but after a while it will flush again and not stop until water is switched off. the solenoid valve appears to be working ok. just wondering if anybody else has had this problem.  Thanks
Welcome to the Forum rayhorse.
Unfamiliar with your problem, but is your flush button; jamming/sticking/loose/etc? ie not it's usual operating mode?
Hi mate everything appears to working correctly. push the button valve opens and closes flush water starts and stops, but it will randomly the water will start running again as if the valve is opening and keeps running. the bowl fills and water all over the floor. I will change the valve and see what happens. this also happens on main pressure and the pump. Thanks for your reply.    Rayhorse
Hi rayhorse, Im having the same issue with my CTS 4110. Did you end up solving the issue?
Thanks in advance, Peter
Welcome to the Forum pb50.
As the flush button activates a small solenoid that opens the valve, that is where you will need to look.
Thank you. Yes, I have a solenoid valve on order. Hopefully that fixes it.
