Post Info TOPIC: Mounting a 1000w Renogy inverter
Hi Guys, Ive ordered a 1000w Renogy inverter and have downloaded the Aus and International manuals to check for any special installation instructions. In the international manual they issue a warning NOT to mount it on a vertical surface since it would present a hazard for the fan opening.
My previous 300 watt inverter was mounted horizontally on a vertical surface (if that makes sense) and I never had a problem. I suppose if the unit is mounted vertically with the fan facing upwards, any rubbish/dust/fluids etc could fall into the fan cavity and cause a problem. Unfortunately this is my optimal position.
Any thoughts?
Zol
When all else fails, follow the instructions.
Interesting as it says, The inverter should never be mounted vertically on a vertical surface since it would present a hazard for the fan opening which is crucial for cooling the inverter.
So can you install it horizontally on a vertical surface? confuse  My belief is yes you can.
I have seen quite a few photos of them installed horizontally and with my Giandel it clearly states you can do it like that.  I think it is just a poorly worded document but send an email to Renogy to check.  The trouble you may get a non technical person replying and not really knowing the answer.
At the end of the day if you are unable to install it horizontally on a vertical surface then that becomes a severe restriction for choice of installation.
-- Edited by TimTim on Sunday 30th of April 2023 09:42:32 PM
How about attaching a piece of angled metal above it to deflect anything that falls on it ... high enough not to restrict airflow. Or mount it the other way around with the fan at the bottom. Presumably this would lengthen the cabling however.
If you are mounting it in some compartment, maybe there is zero chance of something falling onto it anyway.
Looking at another manufacturer's mounting instructions, don't mount the unit with fan at the wrong end. Mounting the unit with the fan at the right end, they pointed out, the potential of things entering the unit.
Just mount it horizontal on a vertical surface if you have to.  Shell be right mate smile
Just make sure you put the right end at the right end, not the wrong end at the right end or the right end at the wrong end.
 "....... if the unit is mounted vertically with the fan facing upwards, ......... Unfortunately this is my optimal position."
Thanks guys. I think horizontal it is.
