Post Info TOPIC: Amenities at rest stops.
RE: Amenities at rest stops.
hufnpuf wrote:
Mariner30 wrote:
If it is too hard for WA to build, maintain and service extra dunny blocks where needed then crikey...
 Have you ever seen a map of Australia? :D
 It would seem not, as there is no apparent appreciation of the vastness of this continent.
When you see signs saying things like "next service 300km" , and you then drive the road you begin to understand, but running around Victoria and up the coast to Queensland is nothing, with towns and amenities every few kilometres.
Last week I again drove from Port Macquarie to Mid Western Australia and I never had any trouble finding toilet facilities. Cheers
You do know that an essential part of road construction is water...and that subsequently water tankers are bought in to provide that essential service.
For the actual roadworks and worker safety etc etc
Again, who cleans and maintains the existing toilets?
WHY is that a hard question to answer for some folk?
when im on the road if caught short for a pee i use a hospital piddle bottle ..........for number 2 i have a fold up seat and a plastic bag to use in the van as its only me traveling im all good in that area with how i do
c b tassell
Mamil wrote:
  What happened to the caravan? Cheers
yobarr wrote:
 Just another draw barbiggrin  biggrin
Don't sell the Sun to buy the Candle
 Because it's so indescribably stupid that nobody can be bothered trying to explain it to you?
You can keep hiding behind trite silly replies however its clear you have no idea about the original post or have the answer to the question l raised.
The crews who job it is to maintain these existing facilities do not drive thousands of kays a day to clean them.
They either work for the local councils or whoever is responsible for road maintenance in that region.
Some workers will be based at either end of the shire or council depending on which town they live in.
It ain't rocket surgery, is it?
All the toilets at at toiletmap.gov.au
If you have to use a spade plant it in front of yourself so you can pull yourself up as after a minute the knees are stuffed.
Possum3 wrote:
I was just reading about the lack of clean facilities in WA, particularly for the ever increasing number of women truck drivers.
Main Roads WA said it was aware of the concerns.
"Due to the remote nature of the WA network and the considerable distance between some of the current roadside rest areas and Main Roads' maintenance depots, the capacity to provide and maintain toilets is limited," it said.
As of June 2020, there were 1,639 rest areas on the state road network.
Toilets were provided at 144 of those sites.
I find it incredulous that a State the size of WA has only 144 Public toilets at rest stops - It's little wonder that the countryside has crap and toilet paper every where.
 I agree, Possum
Although I do not know the answer, and as a West Aussie, I see the need for more toilets at rest stops
I was thinking
If more dump points (which should be cheaper to build/maintain) were built
It may encourage those in self contained RV's/Caravans etc, to use their own facilities, more often
Usual disclaimer, that I have not used a public toilet/caravan park ablution, since covid started, so probably a bit biased for more dump points
Am travelling across the Nullabor atm and noticed the guy emptying the rubbish bins out from Balladonia. Maybe a contract to clean loos could be part of his job. Once a week would help. Koorarawalyee was in need of a good hose out, but at least the dump point was emptied when I was there. Wooralba - black dirty dump with no water, even though the loo beside it has water for a 'pull the handle' job. New toilets at Moondi Rock. Dump points a bit scarce I am finding. Nothing at Eucla, Bordertown is next.
I am reasonably sure that there is a dump point at Border Village, (SA/WA border). I think that I spotted one, (a few months ago), but did not have to use it
Alas on the SA side of the border there is nothing (except toilets at the servos) until you get to Ceduna
Edit to say that there are public toilets at Penong, at the park, but it is not a rest area
-- Edited by Tony Bev on Monday 1st of May 2023 01:03:35 PM
