Post Info TOPIC: Chinese diesel heaters
Hi all :)
Great to be a part of this awesome group. Many thanks.
Yep Ive got one of these awesome wee heaters. The issue I have is that after being unhooked for about 6 months, I hooked it back up onto the same battery that ran it last time and it keeps telling me fault code 2 which says over voltage. Dam thing. Its the same battery that I had on it before but now every time I connect it I get this E-2 code.
Any ides as to what I might try or do?
Many thanks in advance
Ashman
Nonresident Settlor known as Ashley Bruce.
Hi mate and welcome,
I used the following page to get my heater going.
Just be aware that differing types or brands of diesel heaters have different fault codes and different lists for the respective units.
From memory mine was showing fault #2 and it wasnt voltage at all, and I had to prime the fuel back through it to get it to start.
Plenty of info in here on how to diagnose and fault find.
https://www.dieselheat.com.au/information-and-buyers-guides/how-to-guides/diesel-air-heater-fault-finding/
Welcome to Biggs Country many may know it as Australia
This members posts may contain;
The actual truth
If offended, scroll on by.
Hi Ashman,
I just found yet another list of codes.
This may be causing confusion to anyone who may think that they are all the same.
https://www.pinnaclewholesalers.com.au/ebay/no-active/images/2kw-diesel-heater/error-code-for-air-heaters.pdf
-- Edited by Ivan 01 on Tuesday 13th of December 2022 02:55:01 PM
The actual truth
That's a surprising fault and my immediate thought is a fault on the printed circuit board.
However I suggest you "cycle" (remove and replace a few times) all connectors in the system and see what happens.
If that doesn't work then "shake" as best as possible all PCBs you can access.
Otherwise, without component level fault finding, it may be a new heater...?
Ahh now that may be it too as I recal I had similar when installing it.
Cheers for the link :)
Cheers for that :)
I dont think that set is the one though but always useful to have these eh
Thanks Ivan
yes I now have a feeling it may be the fuel needing more priming as just installed a new tank also :)
Will update.
If it is priming it needs to get going, rather than switch it on and off many times you may apply a light air pressure at the tank filler and prime the supply by disconnecting the fuel line at the heater.
When it has fuel up to the heater then just follow the instruction.
If you prime it by switching it on and off it only pushes about 1/2 a teaspoon of diesel per switching if you are lucky.
It has been a while since I did mine but from memory it fired up in 2 or 3 goes after priming.
-- Edited by Ivan 01 on Tuesday 13th of December 2022 07:21:22 PM
The actual truth
