Post Info TOPIC: Honda 5kv generator beeping
Got a Honda EG5500CXS generator that's part of an offgrid solar setup (set to turn on when battery SOC drops below 20%).
Strange thing has started happening recently... after the generator has been on standby (switch = 'on') for a few days, a beeping starts happening.
If I turn the generator off, and back to standby then the beep goes away... for about a day or two, then it comes back.
Any ideas?
I just had a flick through your generator's manual online https://cf.hondappsv.com/files/OM/OM001399AUS/32Z306011_web.pdf  & couldn't see any reference to audible alarms/beeps.
Any chance you have an inverter nearby & if so could it be that sounding a low voltage alarm? I could well be wrong, but wonder if the battery voltage is low turning off the generator from standby mode *might* be just enough to allow the voltage to rise enough to stop an inverter beeping???
A Nomadic Life (Current)
The Big Trip (2008/9)
Thanks Cuppa.
First thing I did was check the manual... as you mentioned, nothing in there referring to beep.
I like your idea of testing the 12v battery that is used to start the generator from standby.
That battery is connected to a battery charger, so it should always be fully charged. But maybe after 10 years of sitting on trickle charge, the battery is not holding charge.
Once you have charged the 10 year old battery. Let it sit for 24 hours to stabilise & then check voltage. With extreme luck it may be ok.
The original starter battery in my car I replaced after 4 years. I used it as a test battery since. The current started battery died after 5 years. I ordered a new battery but it took awhile to turn up so I put back the old battery in the meantime.
I had to do this all with one hand as I had badly stuffed my wrist bending a bit of stainless by hand. Will put the new one in when I am able.
The 9 year old battery originally used for 4 years. 80AH 700 CCA still functions at 568 CCA.
I can self jumpstart with 4 x 26AH batteries (1040 amps 5 seconds or 360 amps for 5 minutes) Had to do this once with the dead starter battery.
From the wiring diagrams there is an Oil Alert Unit. It is not clear if this sets off an alarm, maybe.
I have the 3600 manual start as back-up on my solar system, never had the genny cut out on low oil so never had any alarms.
With your auto start set up it may have an alarm for start failure. makes sense, so yes may be related to battery condition or no oil pressure.
chris.
Chris & Sharyn.
Tea Gardens. NSW.
Will check oil and battery.
Thanks for great advice all!
Had the generator serviced, oil changed, and have tried using a new battery.
Still getting the beep after the unit has been on for around 24 hours.
Stumped.
