Post Info TOPIC: A Warning for EV drivers intending to tow.
I thought this may be good info for some, I think we have a loooong way to go before these things are viable alternatives.
'Too much kinetic energy!' Electric car owners warned about towing trailers and caravans (msn.com)
-- Edited by vince56 on Monday 7th of November 2022 01:13:46 PM
did i not see a advert for a EV that was towing a boat ?
I would have thought that the car would be designed to cope with X amount of weight whether accelerating or braking. A bit little ICE vehicles accelerating or braking limits.
I first became aware of this technical issue when reading about the challenges facing the "longest train" record attempt.
https://www.theautopian.com/the-swiss-just-assembled-the-worlds-longest-passenger-train-and-the-challenges-they-faced-might-surprise-you/
"Additionally, the operators limited the trains to no more than 21 mph. The reason for this has to do with the train's regenerative braking. Kramer says that when going down a hill, the train's regenerative brakes feed energy back into the overhead grid, and there was a concern that with a train this big, the regen would blow fuses in the trains or literally melt the overhead catenary lines. To avoid overloading both the grid and the trains, the operators limited the train's speed and software to limit how much power gets fed back into the grid."
-- Edited by dorian on Tuesday 8th of November 2022 08:21:55 AM
Not an issue with EVs over charging the grid . Even
With their batteries . They have BMS to control charging also . The only way AT PRESENT an EV would work for towing is if its a hybrid .
might have to use the brakes.
