Post Info TOPIC: Defrosting Plate
Defrosting Plate
Very handy if you forget to put out in time.
This one is a repurposed heat sink, (part of) from a Grundfos Pump Panel. So may be heavier than store bought, but works well for us. Takes at least an hour off defrost time on chops or chicken or steak. Dont know about tofu.DSCN7936.JPGDSCN7937.JPG
Cheers Craig
Don't defrost the Tofu - it is easier to toss when frozen.
Note there will be a minor difference in time (ie quicker) if you use a black surface.
Hmmmm...
I reckon... either defrost in the fridge over 24h (best) or do it quickly in the microwave or in a ziplock bag in warm water. The less time bacteria have to multiply the better.
I have found that when camped in one spot for a considerable time, I tend to carry water back to camp in plastic kegs.
The kegs I reuse are 35 litre, square base, and have provision to put plastic tap (www.ebay.com.au/itm/353528090240%3D1&amdata=enc%3A1aSIORDQXQwWQG3f-Mp7dZQ23) .
I have six such kegs that were given to me by a "Car Wash" - Their original purpose was detergent/surfactant containers, they are a food grade container that once rinsed out are ideal water carriers, stable in back of wagon (full or empty), not too heavy when filled.
I sit my kegs on a folding aluminium trestle, beside caravan filler - they are perfect for a gravity fill of tanks - I usually have one under the awning on a small table, used as a water supply when sitting or cooking outside of van.
Check with local car wash - they have a problem to dispose of them.
 35 litre container,you say they are " not to heavy when filled" 35 Kg. or 77 lb.,bit heavy for me. Wow you must be pretty fit Possum,what do you have for Brekky,I want some.
The preceding two posts are not about defrosting plates, so probably meant to be in the thread about blocked vent pipes to water tanks.
Yeah, sorry about that Watsea, I meant to start a new thread - As Dougwe says Uncle Al coming in. Not to worry too late to start again.
Regarding weight; 35kg not too bad (admittedly I used to instruct weightlifting at Police Boys Club a few years back) - It's in the method of carrying ie it is easier to carry two at a time, one in each hand, rather than twisting spine carrying one.
Totally method, not brute strength. My Mother could swing two full 10 gallon milk cans up onto loading table when she was in her 50's - balance and skill.
Oh! Jordans Apple Crumble Muesli from Coles, PT.
Mike Harding wrote:
Hmmmm...
 Plus 1 for that method.
Welcome to Biggs Country many may know it as Australia
This members posts may contain;
The actual truth
If offended, scroll on by.
