Post Info TOPIC: Two, too handy things
DSCN7870.JPGDSCN7872.JPGThe Sidchrome is a rotator as well as conventional ratchet. The handle will twist to rotate the bolt or nut if you are in a tight spot. The black ring rotates to change direction. Red button to easily emove socket.
Cheers Craig
What is the purpose of the ring on the step? And the lightweight chain that seems to disappear along with the red things?
Is it double purpose with a bucket to go underneath?
-- Edited by Are We Lost on Tuesday 20th of September 2022 05:33:15 PM
biggrin biggrin It seems like it might be a bit uncomfortable having to sit on a chain.
Sit, I said.
I said Sit biggrin biggrin
Welcome to Biggs Country many may know it as Australia
This members posts may contain;
The actual truth
If offended, scroll on by.
A W L, designed for a plastic bag, one time use, mainly for widdle stop, so the plastic chain is pretty soft, the red tags retain the bag. Also still can be used as original step .
Lucky we seem to got over the emergency stop thing.
Cheers Craig
KJB
Craig1 wrote:
Just do not forget it is there and maybe full, when you move off.........
KB
