Post Info TOPIC: Two, too handy things
DSCN7870.JPGDSCN7872.JPGThe Sidchrome is a rotator as well as conventional ratchet. The handle will twist to rotate the bolt or nut if you are in a tight spot. The black ring rotates to change direction. Red button to easily emove socket.
Cheers Craig
Status: Online
What is the purpose of the ring on the step? And the lightweight chain that seems to disappear along with the red things?
Is it double purpose with a bucket to go underneath?
-- Edited by Are We Lost on Tuesday 20th of September 2022 05:33:15 PM
biggrin biggrin It seems like it might be a bit uncomfortable having to sit on a chain.
Sit, I said.
I said Sit biggrin biggrin
Welcome to Biggs Country many may know it as Australia
This members posts may contain;
The actual truth
If offended, scroll on by.
A W L, designed for a plastic bag, one time use, mainly for widdle stop, so the plastic chain is pretty soft, the red tags retain the bag. Also still can be used as original step .
Lucky we seem to got over the emergency stop thing.
Cheers Craig
KJB
Craig1 wrote:
Just do not forget it is there and maybe full, when you move off.........
KB
