Post Info TOPIC: Unable to access Wikicamps maps
Hi all. Is anyone having current issues with Wiki Camps. Site data, reviews and icons appear but no maps.
Working fine for me.... make sure you are not in "offline" map option. You need to have the maps downloaded otherwise you see the pins etc but no map.
Western Australia Photographer
https://streetsaheadphotography.smugmug.com/
Ok for me as well.
Welcome to Biggs Country many may know it as Australia
This members posts may contain;
The actual truth
If offended, scroll on by.
If you're posting here on the same device, I'm assuming you have internet otherwise the most common cause of no maps showing is being offline but not the selecting offline map layer. Otherwise there have been quite a few updates in the last few weeks. Are you up to date? Have you cleared cache etc, not downloaded the offline maps but actually in offline mode ?
Thanks for the info. But no go. Contacted wikicamps who have sent a authentication link but the issue appears to be with MS App Store. Will plug on.
Follow up: The problem was caused by a VPN software running in the background. All apps connect/ downloaded Microsoft Store were affected.
tried many times to pay for wiki camps but it kept saying use a different card so now i dont bother with it ......the pay thing is run by idiots ....
c b tassell
You don't pay Wikicamps directly. Purchases go through Apple, Google or Microsoft. If you're trying to pay directly you're on a Scam site.
Tea spoon has made that comment a few times and received the same advice. He has not said which site is causing the problem.
I cannot run Wikicamps on my laptop any more - something to do with a change by Microsoft apparently. Had trouble on the tablet showing only a few icons but sorted by uninstalling and reinstalling. All good now.
