Post Info TOPIC: Internall walls
Internall walls
Hello fellow travelers I own a Windsor caravan around the 80s would anyone know if the internal walls were made of laminated ply or veneer ply or how do I tell the difference as Im thinking of re staining Thanks jmack
Jmack, welcome to GN's.
Plywood by definition is veneered. It is possible to sand veneer lightly with an orbital sander (never a belt sander) using fine grit sandpaper. Normally when upgrading finishes in caravans it is OK to stain darker than original, although any shellac/gloss finish left on surface will inhibit stain penetration to the timber under the surface and could result with a patchy finish.
If it were me; I would lightly sand with fine paper (by hand) and coat the timber with clear gloss acrylic.
Ok Thanks possum3 I will try a small spot first and see how it turns out
