SmartBar SmartBar
Post Info TOPIC: water tank how gauge level
OKA
Soooo..the po of my slide on installed a 90L water tank but with no means of measuring its level.
What are my options to do so?
The lower end has a take off to a regular pressure pump.
The tank itself is accessible for service but otherwise hidden inside a void as is the pump.
My schoolboy idea is a sight tube using a new hole in the tank base and brought out to somewhere it can be seen - probably using a flexible tube over vertical scale.
Other wisdom?
Dave
OKA LT 4WD S/C Ute WIP - Slide on Camper conversion
Hi OKA,
Have a look at these.
They measure accurately the amount of water used in comparison to the volume calibration you set on installation.
Much easier than site tubes but it will cost a bit more.
https://www.topargee.com.au/water-gauges
Welcome to Biggs Country many may know it as Australia
This members posts may contain;
The actual truth
If offended, scroll on by.
OKA
Thanks Ivan looks just the thing!
