SmartBar Camp Creative
Post Info TOPIC: Water Heater problem
Water heater coming out of overflow on 2018 Jayco Silverline. Have released pressure but problem has started again. Has anyone got any suggestions?
If it is only dripping out of the tube that the pressure relief valve is on when the water heater is on (gas or 230v) then that is normal. The hot water cylinder is pressurized when the heater is on due water expansion. Nothing to worry about.
These heaters have over pressure/temperature valves which sometimes stick, they usually have a small lever on them - try activating this lever a dozen times or so (more water will spill) and see if that helps.
If it doesn't then call a plumber.
