Post Info TOPIC: rear axle
rear axle
hi all
can any body tell me the max rear axle loading for a 105 land cruiser
cheers snap
Toyota would be my 1st call
snap1946 wrote:
hi all
cheers snap
 'Tis 1790kg. Front is 1390kg. GVM is  3180kg and GCM is 6680kg. Wheelbase is only 2850kg. Don't even THINK about towing any more than about 3100kg as a PIG trailer  (van) if safety is of any concern.Great car though. Happy to help you with weights if you wish. Cheers
-- Edited by yobarr on Friday 17th of June 2022 06:39:08 AM
 Good luck there, but why would you bother when such information is easily found online. Probably in owners' manual too. Cheers
yobarr wrote:
snap1946 wrote:
hi all
cheers snap
 'Tis 1950kg. Front is 1630kg. GVM is  3180kg and GCM is 6680kg. Wheelbase is only 2850kg. Don't even THINK about towing any more than about 3100kg as a PIG trailer  (van) if safety is of any concern.Great car though. Happy to help you with weights if you wish. Cheers
thanks for that
is that for the 105 series or the 200 series
  snap
-- Edited by snap1946 on Thursday 16th of June 2022 07:55:36 PM
-- Edited by snap1946 on Thursday 16th of June 2022 08:03:04 PM
Deleted
-- Edited by yobarr on Friday 17th of June 2022 09:57:49 AM
snap1946 wrote:
yobarr wrote:
snap1946 wrote:
hi all
cheers snap
 'Tis 1790kg.. Front is 1390kg. GVM is  3180kg and GCM is 6680kg. Wheelbase is only 2850kg. Don't even THINK about towing any more than about 3100kg as a PIG trailer  (van) if safety is of any concern.Great car though. Happy to help you with weights if you wish. Cheers
thanks for that
  snap
 Hi Gordon.. Bit tired last night and gave wrong figures, now amended. Can't guarantee they're correct, but that's the best I can find at moment. Sorry. Cheers
-- Edited by yobarr on Friday 17th of June 2022 06:53:00 AM
Deleted
-- Edited by yobarr on Friday 17th of June 2022 09:56:32 AM
Geez, what a mess to a simple question.
There must be an owner with a user manual with specs who can answer.
The OP appears not to have the manual details.
Cheers, Richard (Dick0)
 Didn't notice you rushing in to offer any help here, Dick. Unless you can offer an alternative set of figures it probably would be nice if you kept your thoughts to yourself? Not all user manuals show rear axle ratings, for obvious reasons, which may be why the OP asked here for help? Experience tells me that calling Toyota for help with things like this is pointless. They simply don't know, and on this question I spent a lot of time seeking answers. There are many variables that affect the axle rating, even down to what fuel the car uses, but the figures that I posted were the best I could find. An ounce of help surely is better than a pound of criticism? Cheers
Cruiser 105 owners manual detail (we own one).
GVM must not exceed
GVM with 1HZ diesel motor - 3180kg
GVM with 2UZ-FE motor or 1HD-FTE motor - 3260kg.
Axle loads must not exceed following.
1HZ- Front 1550kg, rear 1950kg
2UZ-FE and 1HD-FTE - front 1630kg, rear 1950kg.
That is straight from the owners manual for a 2006 Standard 105 Landcruiser.
Hope that clarifies things.
-- Edited by TheHeaths on Friday 17th of June 2022 08:31:25 PM
Regards Ian
GVM must not exceed
 Thanks Ian, for providing  these facts. These are the same figures I have in my records, and that I supplied initially, as evidenced in Snap's post at 7.48pm yesterday, but further investigation had me doubting their accuracy, so I did a lot of research, finding the other set. Thanks for removing any doubt. I now will put a tick alongside the figures in my records to show they're all good! Cheers
thanks guys that is what i was after after talking to toyota which was useless and looking at manuals the same
some guys on here know their stuff which why i asked
thanks yobarr and TheHeaths
cheers snap
cheers snap
 Thanks Gordon, for letting us know that you're sorted! So many don't bother, so it's refreshing to have assistance acknowledged. Asking Toyota never was going to be an option. Good luck with your travels. You've got a good car there.. Cheers
yobarr wrote:
GVM must not exceed
do you think the 2000 model 105 would be the same
snap1946 wrote:
yobarr wrote:
GVM must not exceed
 Sorry, but can't help there as that series ran from 1998 to 2007, with the turbo-diesel introduced October 2000 to further complicate things. Different engines came with different ratings, which is where I stumbled on the second set of numbers I posted. Perhaps you could try the LCool forum, but it's a nightmare to navigate! You may be able to do your own research if you get all details from your car's compliance plate, particularly year/month and engine number. Good luck! Cheers
Might get some joy having a look in the landcruiser forum at LCOOL.ORG.
Real people, real info from owners experience.
 Was this not my advice in the post above! Cheers
 X2
