Post Info TOPIC: 240 volt cord into a tent
has anyone got a good idea how to get the power cord into a tent as mine has a floor .........without using the door .......is there a fitting to run the cord in maybe ............or is there a bright idea someone has ......cheers
c b tassell
We have a fully enclosed tent/screen enclosure, can't you sew in a flap with Velcro where needed. Probably about half hour job by hand with needle & thread. An hour at worst.
My tent has a special area where a 240v line can feed through into the tent.
Derek Barnes
I cannot help but wonder why you do not take the flex in via the door and then do the zip up as far as possible?
I think he doesn't want to trip over it, which may happen as he is an elderly gentleman, as well as he doesn't want to walk on it. As I am a bit younger I would feed it in thru the front door, up against the zippered part and around the other side of the tent wall, ( left or right side). These are the things you should bring up when you buy a tent, or any product, but doing this, is rather an afterthought until you put your tent up. You should be able to replace/ return the tent, with one that has a cord inlet , they can be a bit dearer, but as you have sold your van, you may have a little bit extra cash to to it.
-- Edited by Bicyclecamper on Monday 6th of June 2022 02:22:54 PM
Ric - The Eccentric One
solved the puzzle its a small area near the door that the cord goes into the tent thanks all for you ideas and help .....cheers from me maybe ill see you out there eh ......
c b tassell
Sounded like a third world problem at first, I am glad you got it sorted.
Welcome to Biggs Country many may know it as Australia
This members posts may contain;
The actual truth
If offended, scroll on by.
Always good to have a pic of the solution.
Cheers, Richard (Dick0)
if some clever person can put a picture of a Weisshorn tent-c-ca4 on here it has on the left of the door a slanted piece of canvas that the cord goes through behind and it velcroes shut...so as i posted all is goodo
c b tassell
