Post Info TOPIC: which 200 ah lithium battery should i get ?
best thing is the size it's only 110mm wide slimline, so takes half the space in rear of car, leaving enough room for fridge slide and draws in rear, perfect. I've noticed even when car parked under carport, system still draws in solar charge , so fridge runs 24/7 with battery still at 100% while stationary. fyi
www.youtube.com/watch
https://www.youtube.com/watch?v=phuJVtVQ0dM
https://www.youtube.com/watch?v=irb-vdTnY7M
https://www.youtube.com/watch?v=AlvnH-0gjSQ
Dick0 wrote:
Hylife wrote:
http://www.lowenergydevelopments.com.au/batteries/LithiumBatteries
 Nice batteries for sure, but out of my camping price range, and specs more for off grid home base systems utilizing high end 240V inverter multi appliance energy usage.
Only $240 difference (pick up) and you get a huge 5 year warranty!
Freight on Lithium batts is expensive because the old chemistry ones were dangerous goods class, so take that into account.
Kings might be offering free freight now but by the time they actually get the products into Oz you can be sure that will change.
And, considering Kings don't even have a 200ah LiFeP04 battery yet, (yes that's right, this is a pre-order deal for some time unspecified in the future), L.E.D. have the best value for money.
I have two of L.E.D.s 100AH LiFeP04 batts in parallel. No issues for 3 years so far.
My van has a Morningstar ProStar controller and these are programmable so once I set up a Lithium charge profile they were simply a drop-in replacement for the two dead 18month old AGMs.
used to sell batteries in a past life, if you look closely you will see they only have stickers on them, we changed brands once and the new suppliers just came and changed stickers over. only about 2 manufacturers supplying every brand.
12V 230Ah LiFePO4 Battery with BLUETOOTH BMS
$1,485.00
BAT-EVH12V230AH
Sealed LiFePO4 Battery 12.8V 230Ah with full internal protective Battery Management System.
BLUETOOTH PHONE INTERFACE for displaying battery information on your phone!
These batteries can also be connected two in parallel to double the Amphours or two in series to make 24V.
NOTE: WE OFFER FREE SHIPPING AUSTRALIA WIDE ON THIS PRODUCT.
 Look at the data on these batteries, they are on a serious diet. Probably another box with a high percentage or air. Would be interesting to see a teardown.
Lozza56 wrote:
I've had my 170ah Lithium battery for only 2 months, put it in back on my Landcruiser with a 210w Solar panel on car roof, plus a Redarc charger from 2nd battery.
main use is my 85lt car fridge, got sick and tied of camping, having no power from 2nd battery after few days, so yeh, good set up, solar charges initially, then Redarc takes over if no solar. point is we've all had fridges not work, just want cold drinks and meat etc in car fridge, next will be 2 Lithiums in caravan
 Havnt had issues with 200AH AGMs .  Over 7 years .its the whole package from solar, regulator and batteries .  No point having twice the batteries if charging solar / from 240 is not up to spec .  Some van manufacturers rely on motor to be driven every second day also or plugged into 240 !
I don't understand the claims of "on a serious diet"?
All LiFePO4 boxes are half empty, as manufacturers persist in conveniently using standard sized cases of equivalent capacity lead acid batteries, and four lithium cells don't take up much room in a standard sized case.
Four quality 100ah cells would weigh in at around 9.5-10kg
And, remember, we are talking RV usage where 99% of users will draw smallish currents over a long duration.
Most every LiFePO4 cell made has a recommended max rate of 1C discharge or charge.
If you really need to run and actually use the full capacity of that 2,000 or 3,000 watt inverter, then just get two or three 100ah batteries and hook them up in parallel rather than a single 200 or 300ah battery.
Surely 200 or 300 amps continuous draw is enough for the vast majority of users.
My two 100ah units in parallel have no trouble running my 1,500 watt inverter for the 1100 watt microwave, but sucking out 170 amps for an hour of microwave takes two days full sun to recharge with 450watts of solar panels.
Well at least Low Energy Developments has a shop front and are selling more than just batteries unlike many cheap lithium battery sellers.
 Their 200Ah battery only has a 100Ah BMS and discharge current of 100A which may not be adequate for some users.
The weight of batteries has been discussed before.  Eve 100Ah cells weigh 1.92kg give or take 0.1kg.  Four of those plus a bms, some cables and a case will come in well below the weights of some batteries advertised.
Most of these batteries are just standard cases with a sticker on but you can also get printed cases from China.  I would be surprised if any of them apart from Itechworld which has the Redback BMS are actually put together in Australia.
-- Edited by TimTim on Wednesday 15th of June 2022 09:30:10 PM
Hi,
Try Aussie Batteries https://www.aussiebatteries.com.au/ I have had 2 x 140 ah Lithiums, (one in the van and one in the tug canopy) and have been on the road for 6 months with no issues.
Aussies provide great service and have responded to a couple of technical questions within 24 hours.
Dave
