Post Info TOPIC: a/c only dropping ambient temp by 5 degrees
I've got a 19ft van with a Dometic CK36H401RI2 roof mounted a/c unit
I've been running the a/c and its only been dropping the van to about 5 degrees below ambient (ambient temp has been around 30 degrees)
according to the manual it has a 3124w cooling capacity and it should be sufficient for a van up to 7.5m
should it be cooling better than this, or is this normal for a/c on a van?
I've pulled the external cover off and cleaned the condenser and also cleaned the return air filters
we're on our way up to Darwin and I'm wondering whether I should book it in somewhere up there to get it re-gassed?
Get the gas levels checked.
Neil
Neil
 X2
Any ideas who to goto in Darwin? Do I need to goto a caravan specialist or an automotive a/c specialist?
You won't  want an automotive aircondditioner as it is a 240v unit not 12 v hich all automotive can legally repair
Neil
If its low gas it wont matter but I would search AC specialists! Covers all ! All the condenser, vents etc CLEAN ?
 My good friend Mr Google suggested you try Pratt Caravan Repairs! Never dealt with this company but might be worth a shot? Cheers
You need a Refrigeration Mechanic
Google would be your best friend for up there
and be prepared to part with folding
Bob
