Post Info TOPIC: Small retractable awning.
Hi all, Where do I go in Adelaide, (South would be good) to enquire about a small awning to fit on the rear of our Pop top. Cheers. DR.
Karl Marx.."the masses are the asses" Groucho Marx.. "I never knew my brother Karl"
 You are likely to find what you're looking for at one of the "4wd supacentre" stores,of which there are several in Adelaide,I believe.About $100 is all you'll need.Good luck.Cheers
Edit.... Sorry. Retractable Awning. Do they make them 1.800 mt wide. ??
Cara-Rest Grand Junction Rd Kilburn (Next to Dave Benson Caravans.
RV Superstore Plus Kettering Rd Elizabeth South.
 Seen them down to 1400mm wide to go on rear of Nissan Patrol etc.Roll out to 2 metres long.Cheers
Try Darios Caravans, 1 Pinn Street St Marys, just off South Road south of the city. If they can't help I am sure they can point you in the right direction, ph 82774388
Ian
DIY.
About the size you want?
Thanks all. I may not have been clear. What we want is spring loaded, the same as on the side of most caravans, not the type from a 4x4 shop that we see on a car.
Eezi spring loaded retractable awning 1500mm wide. If it is still too just cut it to size. Just a bit of elbow grease.
Open : 2100mm L x 1500mm W
Closed : 1500mm L x 115mm W x 100mm H
Leg Height (Fully Extended): 2300mm H
