Post Info TOPIC: OBVIOUSLY A SCIENTIFIC EXPLANATION
Heres a question that would be on everyones mind.
Yes, The stick is obviously there to poke away any excess toilet paper or Poo BUT
Which end of the stick is used to poke with and which is used to hold it with.
That would be a sheet stick then?
Kebbin
Go for the dry end, or the one with nothing on it. Conversely, get your own stick.
Wouldn't matter if gloves were being worn,would it? Cheers
One member on here uses those little " bones" for his fire. May not be any sticks?
Cheers Craig
Pick the stick up and smell each end, the rest should be self explanatory.
 Depends if their $hit don't stink, or it might be 'sticky' poo.
This post should be flushed away.  smilesmilesmile
Make it Snappy......Bob
I've never had solids that needed poking down any dump point
if the additive you use works properly, there are no solids in your crap.
if so, maybe a change of diet to ensure that your stools are soft
re the stick, give it a lick to see if you can tell which end to use? :)
Sponge-on-a-Stick-the-Roman-toilet-paper.jpg Could be the remains of a Roman butt sponge!
 I like it!!
think I might poke it with a jet of water out of that there hose.biggrin
Not sure if there is a scientific explanation
But...
Logic tells me, that the sticky end of the stick, is the end I would use for poking
They could do with this type of poker on the current WDH thread.
Kebbin
Why would you use a stick when the hose would do the job?
Iza
Status: Online
ever heard the expression ****abrick , you might need a bit of vivid imagination and think of extreme constipation
It might be to scrape down spider webs.
 Sh-t a brick and fart a crowbar was often heard many moons back.Cheers
