SmartBar SmartBar
Post Info TOPIC: Waeco will run on 240v but not 12 v
Sorry if this one has come up before.. I put Waeco in the car with engine running and plugged it in.. wont  go
Runs as usual off the 240 v lead
have checked the fuse in 12 v lead pug and it is good
I see on a search that the poly fuse may have gone
any ideas fellow GNs
Phil
Which model? VERa or VERb 2 totaly diferent units.
D.L.Bishop
Hi DeBe
Details on Waeco
-- Edited by Cisco kid on Thursday 25th of November 2021 04:47:30 PM
Phil
Hopefully the pic of the circuit board will help to identify if my Waeco is Vera or Verb
Phil
The compressor is 12V so I would conclude that it is not a big problem.
DANFOSS 101NO500.JPGIm asuming then this is the compressor controler? On 12V DC does the display light up? Is there 12V on the pos & neg terminals on the controler?
D.L.Bishop
D.L.Bishop
Thanks DeBe
I will pull the fridge apart some when I get back from road trip and keep you posted
Phil
You wouldnt believe it , I made up a new lead for 12 v and connected it up to a 12v deep cycle battery and she fired up lights and the compressor ! Many thanks DeBe
Phil
