Post Info TOPIC: Flashing ljghts
Flashing ljghts
The interior lights flashing on and off.
We"re on the road to nowhere and looking forward to meeting you there
Bad earth?
Some LED Lights are not compatible with electrical systems - this can cause flashing house lights.
Patrick, you are being overly cryptic here. Please tell us the full story? For example, is this happening, what is the timing of the flashes. Is it happening when the lights are supposed to be o or when they are supposed to be off?
-- Edited by PeterD on Thursday 25th of November 2021 11:14:36 AM
Peter_n_Margaret wrote:
Bad earth?
No, it's fine.
It's all those people putting nasty gases into the atmosphere.
This is Techies, not "joking ", but a good one Mike
Cheers Craig
Turn up the music. Be back in the 80s at the disco.
Sometimes you can get dirt in you on off switches especially if you have done a lot of off-road driving and experienced some dust inside your van
The fix is to get an electrician to open up the on off switches inside the van and blow out dust check terminals etc
-- Edited by Cisco kid on Thursday 25th of November 2021 05:28:10 PM
Phil
Check the circuit breaker . On lights they fit re closing type so the lights DONT go out totally!! Check fuse board ? Its often a little square silver block with two spade terminals . It could be tired ? Or the globes are higher amperage ? Or short ?? In an emergency a fuse can be used to get home .. like this 9E514A2D-0894-4DD6-ADE0-8CBFCDD72B5D.png
-- Edited by Aus-Kiwi on Thursday 25th of November 2021 05:47:58 PM
PeterD. Plugged Power cable via inverter into house outlet. LED lights in van flash consistently
 Is it this one?
download.jfif (8.2 kb)
Christmas lights ?
I assume the power cable is a 240 volt lead feeding an appliance that you have plugged into an inverter which is in turn plugged into one of the vans
12 volt cigarette lighter type sockets. Is this correct ?
If so how many watts is the 240 volt appliance ? what is the output of the inverter ? How heavy are the feed wires to the 12 volt socket? I think all
this is probably relevant before anyone can help you.
Landy
This problem solved. Battery was not charging. New battery all systems go.
thanks for coming back an saying what the fix was, many don't
 You're not camped near Boulia are you? It could be the Min Mins.
Nature, the cathedral of awe.
Lucky they are not red and blue lights ? Have you pulled over ?
