Post Info TOPIC: Shower flow meter
Shower flow meter
Gday,
Has anyone fitted a flow meter in their shower?
Im after an inline flow meter to fit to the shower hose so I can measure how much water Im using.
I only want something cheap with a big enough readout that I can read without my glasses on, without trimmers, temperature gauges etc.
Everything I've found has either has a too smaller screen or too larger inlet and outlet.
Any ideas
Hairyone have you considered putting the plug in bottom of shower? That will give you an accurate measurement of water used.
Hold a 1 litre (or known volume, or weight it after) container under the shower rose and time how long it take to fill. Then you can calculate how many minutes you have between getting damp & drowning!
Im after an actual flow meter so I can say, for example we have 2 nights left and 60l of water left for showering....so were allowed 15 lts each per shower
https://au.rs-online.com/web/p/flow-sensors/5114772
Have a look at the topagee flow meter .when your tanks are full it counts back and shows how much water you have used each time and what's left.
Trevor
 Doesn't your van have gauge on tank/s?  If not, an easy retrofit, a much more reliable methodology to determine residual water.
My new caran build is having a full Enerdrive system fitted, including a Simarine monitoring system.
It will tell me how much water i have in each tank to nearest 100 ml.
Grey water, and fresh water. I can monitor my water use very accuratly.
Graham Day.
Not all those who wander are lost.
A little off topic. But might help. I'll fit one to the second tank this week. Guaranteed to be accurate. Just not very convenient.
thegreynomads.activeboard.com/t67912476/water-tank-guagelevel/
Sta
If you are looking for an accurate figure as you suggest, then you need an input/output meter, as van tanks are notoriously different in volume accepted to the nominal figure.
You will need accurate input volumes to ensure your output reading is correct.
Regards Ian
Hairyone wrote:
Gday,
Any ideas
 Hoselink have one that will do what you want. You will need a few fittings. I use one on my return water from the hot water diverter back to the tank.
Chris.
Chris & Sharyn.
Tea Gardens. NSW.
https://www.hoselink.com.au/products/nozzle-flow-meter
Chris & Sharyn.
Tea Gardens. NSW.
Hairyone wrote:
Gday,
Any ideas
 We use a 9 ltre bucket under the grey water outlet, wife uses 6 litres to have shower, me 8 litres. There would not be a cup or 2 difference between our showers uses and I know because I empty the bucket.
