Post Info TOPIC: DC DC charger
DC DC charger
What do you recommend ? Probably around 40A Will be mounted external at this stage, so Enerdrive and a couple of others are out. Anyone using Matson ? If you are, can recommend ? Thanks
I use two 9 amp Victron DC-DC controllers in parallel, use can use as many as you like.
Red arc built to last
Mitsubishi GLS Pajero,   Jurgens Lunagazer caravan.
Also Toyota FJ Cruiser  missus wont let me sell it, sigh
I use enerdrive myself but it is an inside unit
Not sure what you are trying to do, but if you have 14+ volts at alternator or off regulator from solar panels a thicker cable to reduce voltage loss will do the job with a big cost saving.
