Post Info TOPIC: Toyota predominantly 3.0l
What are the thoughts of towing with this vehicle caravan weighs 2.7 tonne
Geoff & Kay Wood
Port Victoria. S A
Landcruiser 100 series  automatic turbo
Retreat Macquarie 22ft caravan
RE: Toyota prado 3.0l
Is 3.0l under power
Geoff & Kay Wood
Port Victoria. S A
Which year Prado are you looking at?
I ask, as many Prados have maximum tow weight of van of 2500kg, and from a previous post of yours I think your van is nearly 3000kg. I see you say it is now around 2700kg.
I would certainly look for something else even if the Prado is rated to 3000kg, as it would be too close to maximum. I did tow 2250kg with a 2006 Prado, and I wouldnt have wanted to go much heavier.
-- Edited by TheHeaths on Thursday 7th of October 2021 08:27:29 PM
Regards Ian
 What is the car that you plan to use,or did the computer decide that your Toyota Prado was a Toyota Predominantly? Assuming that your car is indeed a Prado 3 litre,maximum towing capacity is 2500kg,with maximum ball weight of 250kg.However,with an 1800kg rear axle you could load it up a bit! GCM,or total weight of car and van,is 5490kg,but you CANNOT tow your 2700kg van.Cheers
 Apparently there is such an animal as a 3 door Prado,with a 3 litre motor? This model CAN tow 3000kg ATM.Cheers
geoff wood wrote:
Is 3.0l under power
 Not underpowered,but definitely overloaded,unsafe and uninsured if towing 2700kg.Cheers
Thanks for your reply regards Geoff
Geoff & Kay Wood
Port Victoria. S A
