Post Info TOPIC: Tyre pressure monitoring systems
Re (But it was because of Safety Dave large screw on sensors that caused the valve to fail in the first place as they do not fit in the recess of the rim and the valve are distorted)
Re Sensors that screw onto the valve stem.... Ensure that new Valve/stems are replaced with every tyre, sometimes this is not done and the weight/G force of the sensors (at speed) can cause the tyre valve to leak.
Have posted this previously, but A small length of 13mm soft/ ld/ garden poly pipe takes up most of the slack between rim and tyre valve, cut to suit your rim so that it finishes immediately below the screw on sensor.
Cheers Craig
BarneyBDB wrote:
I have just ordered a couple from here www.banggood.com/search/tire-pressure-monitor.html
 Hi Barney,
Has your TPMS unit arrived yet?  If so, any feedback from you about its performance and usability? Thanks in advance.
I use metal valve stems and 2 per rim. They last 16 years and counting.
How about this multi wheel unit for trucks, vans and rv's. Sold with 6/8/10/12 or more sensors etc. and well priced.
Looks like it will work with 40 sensors.
Cheers, Richard (Dick0)
