Post Info TOPIC: Solar panel
Solar panel
Just bought our second campervan. First time around was a Mercedes Sprinter and this time a cheaper, smaller Mazda E2000. It comes with a solar panel that can attach to some brackets on the roof but the seller said she'd kept it loose in the van and just plugged it in when she stopped. Question is; what do you do? Roof mounted or loose?
RP Matthews
Welcome to the gang Paul and Val, enjoy here and out in the playground.
I had both, 450W on roof of aluminium tent and a solar blanket. After the initial test of the blanket I never needed it after 4 years so only a month ago gave it to my daughter for their new camper trailer.
Keep safe on the roads and out there.
Lots of roof mounted.
Set and forget. We have better things to do that mess about moving panels.
hi smile
My thoughts having done both ! Fixed on the roof is easier and always working if the sun is on it. If that is enough to 'keep the lights on' and give enough power then fit and forget, but the flat on the roof position is not the best for power.
If you need more power or like to park in the shade then a portable panel does enable you to get more power by chasing the sun, moving it a few times a day to a good angle and position, to optimise the power. But you do need to do some work and security is not so good.
Your choice. Or just get two panels and fix them !
jaahn
We have a portable solar panel. Didn't use it once on our last trip BC (before covid). The longest we stayed in one place was 4 nights & the car will charge up enough before we next stop for the night.
We can go 7 days off the battery.
 X2.No brainer really! Cheers
 X3, for 3 months our panel are on the roof.
Jaahn wrote:
hi smile
jaahn
 Yep. I have 160 on roof and a 120 portable. Only move portable 3 or 4 times a day.
P.S. if you don't want to move it just lay it on the ground.
-- Edited by oldbloke on Monday 30th of August 2021 06:18:19 PM
Sta
Hello Paul and Val,
I hope you enjoy your new toy.
A portable panel gives you the opportunity to park in the shade and still charge the batteries, something to consider if you are venturing to warmer climes.
Hope this help.
Bob.
The 120W panel on my caravan roof is all but useless when I camp in the forest however my 160W portable panels do quite well if the tree cover is not too dense and I move them three or four times per day.
 Agree.
Make sure you have enough cable. My panels plug in at the rear of the car, but if the available sun is out the front you need additional cable just to get past the car.
If desperate I can use my jumper leads for an additional 6 metres, totalling 20 metres.
