Post Info TOPIC: Light bulbs
Light bulbs
I have a 2002 Avan cruise liner and over the bed there are two round 50mm dia lights. My problem is that there were no bulbs in them and I cannot find out what I should buy. I want led bulbs but am not having any luck at the stores l have visited. If you have the sams van l would love to hear from you.
Hi Clums, What is the connection, edison screw, normal bayonet, post bayonet? just measure the internal diameter Jaycar will have LED's to fit.
 There are two small holes about 4mm apart, you can buy a complete housing but they do not fit. I will try jaycar. Thanks for your input.
 Post bayonet, push in and turn - similar action to Flourescent starters.
They are bi-pin probably halogen.
Jaycar has LED replacements.
Chris & Sharyn.
Tea Gardens. NSW.
 As soon as we are allowed to leave home l will be going to Jaycar. Thanks for your help
Here's an extract from our 'Aliner for All Seasons' website :
We have changed all the internal 12v incandescent lamps to low current LED type (Duratech ZD-0360 and Duratech ZD-0488 from Jaycar).
Your Cruiseliner should have the same interior lights as the Aliner.
Regards,
 Thank you everyone who replied. My son in law got my bulbs at Jaycar. ecolume MR11 LED Lamp ZD-0650
