Post Info TOPIC: Pin holes in carefree awning
Evening forum members,
On rolling out carefree awning as a pre-trip check, we (the wife) noticed some pin holes in the fabric. I think I read, some time in the past, that you can use liquid paper to fill the holes?
If not, can I smear a small dap (smoothed out) of wet area clear silicon, sikaflex or seam stitching sealer. I am trying  to stay away from using patches if possible!
I believe in the USA the have a liquid patch product, I can find any available in Aus. Do we have a similar product available in OZ and where can you purchase it.
As in previous post thanks for all or any advise/ suggestions.
JohnZ
JohnZ
 It is nicer to thank the respondents after they have replied. It shows you have read them and appreciated them.
PeterD wrote:
JohnZ
 Peter,
If you go back an read any of my previous posts that I made, which I know you have, you will note that I generally close my posts in this manner or similar: its to thank people for reading the post in the first instance and also in the hope of advise.
You would have noted that when I do receive a reply, that I have always responded and thanked the members who have taken the time to reply to me. If you go back on this forum and also another, I have had the courtesy to thank you when you gave me advise on issues: on this and the caravaners forum.
John.
-- Edited by J_KZ-1 on Sunday 25th of July 2021 09:45:36 AM
I used a drop of Araldite to plug a pinhole leak in an inflatable dinghy and it lasted for years until I spilt petrol on it. I'm sure it would do the job on a vinyl awning and be virtually invisible.
I had the same problem with our new van. Noticed 3 pin holes on 1st attempt at putting awning out (Carefree). Fortunately, replaced under warranty.
These should have been noticed on assembly by manufactures!!
Dick.
Thanks for the tip Are We Lost,
Ill try it on one hole first to see how it handles being rolled. There one about 2-3ft from roller end this will be the tightest end.
Thanks again For the tip. ( i will attempt not spill petrol on it but )
Totally agree with you Dick,
Ours is only 4 year old, insurance replaced it after a storm. Holes may have been there from new and havent noticed!
-- Edited by J_KZ-1 on Sunday 25th of July 2021 09:43:35 AM
We experienced similar problem with Dometic Awning - Pin hole leaks in brand new awning - My personal opinion is van owners are being supplied sub standard vinyls by manufacturers maximising profits.
I've successfully patched matchstick size holes with silicone; a slight dab on either side. It's flexible, has good adhesion and stands up to all manner of weather conditions. However, it does discolour over time.
Totally agree possum, profit before customer satisfaction.
warranty is only there too let you know how long its going to take manufacture/supplier too acknowledge receiving your claim only not acting on it.
Thanks me in,
I give a couple of holes a try with silicone, I presume external guttering type silicone would hold best.
Thanks again.
john
I wouldn't use a hard glue on fabric awning. I used a fair bit of glue for years & would get drops on clothes accidentally. Months later the fabric would break around the edge of the glue.
Thanks for the advise whenarewethere.
Do you consider silicone a hard glue?
John.
Silicone is flexible. Probably best if it's a low acid type.
What about tent seam sealer, it's probably silicone based, probably worth looking at. At least for research purposes.
I used Parfix Roof & Gutter silicone.
Thanks again whenarewethere,
Ill research yours and meins suggestion reproduct to use.
Thanks mein,
As with whenarewethere,
Ill research the products.
https://www.bunnings.com.au/gorilla-48mm-x-8m-clear-repair-tape_p1662684
I used this to repair some delam's and pin hole, for the pin hole I cut out 2 circles approximatle the size of a 20 cent piece, cleaned the area around the pin hole with metho and applied over the out and inside of the awning, done similar with the delam's went but laid the tape approximatly 4" before and after the delamination.
Hey Gundog l used that tape also for a tear and it lasted till my awning finally met its maker.
Home is where I park the rig.
Tug 2016 D-Maxine
Den 2009 Goldie RV
