Post Info TOPIC: Caravan Universal tool - to save weight.
No photo description available.
That is almost as good as permanently loosing what'shername!
Status: Online
That is not a "Whatchamacallit" Possum
It is just a normal Stillson Pipe Wrench, with the normal hammer head, 1/4 inch six sided socket, and 1/2 inch ratchet attachments, welded onto it
I will admit though, you would have to be a real dinki di, watchacallit type man, to have one in your caravan
Because
smilesmile There is not a lot of call, to carry a stillson pipe wrench, in a caravan smilesmile
Dmaxer has one nearly the same as that. He uses it to adjust his WDH. He had to modify it when he first got it cos his van was over it's ATM. Power was provided by his generator to do the welding.
 Au contraire, I have assisted a few out on the wallaby effect repairs utilising stillson wrench, from wresting stubborn damaged Tow balls to underbody suspension components.
What, no bottle opener?
 As usual Possum,you are right! In my car there are two Stilson wrenches,one at 18" and the other at 36".Always they are handy to have,for both my own use and to help others.Probably no need to carry things like taps and dies,or ezy-outs,but I carry those too! Cheers.
Status: Online
 Then I stand corrected
I am fairly sure that in my past life, of being a Fitter
I still have a 36, 24, and 18 inch pair of stillsons somewhere in my shed
But I would never dream of carrying them, when I travel
Because
 Silly me I carry a red stillson and blue Aldi one, been known to loan them a few times a year.
Hope I am not jinxing myself.
Be perfect when camped up and bored. Just pull it out and do the tappets on the motor...
FNQ
 If you set the Stilson jaws at 5/8" open they make great bottle openers.
ps I'd replace the phillips head screwdriver with a wine cork screw.
-- Edited by peter67 on Monday 12th of April 2021 04:46:54 PM
 Even the vintage drops now have screw tops (another use for Stilson Wrench) so no need for corkscrew.
 Mate I even carry umbilical clamps in FA Kit - you just never know.
I tend to carry all sorts of tools and stuff. I've been ridiculed for carrying a terminal crimper and a load of various connectors and have never used 'em until last week. An errant stick or something destroyed one of the camper brake cables - simple fix, crimp a couple of joiners on and off we go.
Funnily, although I've never used it, ever, nobody ridicules us for carrying a fire extinguisher though. Never used road side assist either but apparently it's also a must have.
The multitool - never say never...
-- Edited by markf on Tuesday 13th of April 2021 11:31:56 AM
Mark F...
VK3KW
2010 Outback Campers Sturt
http://jandmf.com
Is there a left-handed version?
TimM
YES! flip it over.
You need a left hand thread, so flipping it over doesn't work.
I have an alloy one . Light as !! No good for hammering though !!
 I was being flippant.
