SmartBar
Post Info TOPIC: Sump Plug
Sump Plug
No photo description available.
How tight should the sump plug be?
snice n tight
Cheers Craig
and tight only, and then a bit more tight, to be sociable
If you have to use an ammer and spanner to remove, a sump plug, you had been much too sociable
smilesmilesmile This is why us smaller chaps, are better at maintenance, we know what and tight is, as we do not usually overtighten bolts/plugs/nuts smilesmilesmile
