Post Info TOPIC: New suspension on an old (er) van
Wondering about upgrading the suspension on the 2003 Millard Weekender.
Specs are:-
Specs are:- 2003 Millard Weekender 15ft.
ATM 1220 kg. GTM 1105kg Tare 900kg, Tyre size 185 R14 LT, Axle Load 1450Kg
Axle Diameter = 60mm (Measured)
Clearance between Tyre & Wheel Arch = 110mm
5 leaves (Leafs??) . There's some corrosion here.
Use - We don't need to go up "Big Red" at warp speed, Outback Roads with maybe a shallow rocky river crossing would be the limit.
I've checked with Pedders & they suggested that I try a trailer manufacturer.
I know that the superstructure isn't designed for off road use but being aware of that would mean that I'd be taking it easy.
Possible?
Thanks
Is it possible that the leaf springs are welded together by rust and just need to be stripped and cleaned, maybe a grease up as well?
 NEVER put grease between leaves of  leaf springs.Cheers
 Correct.
Why do you think you need an "upgrade?
A worthwhile improvement may be to add shock absorbers.
Springs have sagged . Its lost its supple ride height . Progressive spring . Now its ridding on ALL leaf springs at ounce ? Some fit Teflon on outer leaf to allow smooth operation .
Go to a Jayco dealer/repairer and get a set of Discovery leaf springs - Slipper springs will handle a little rough stuff easier than fixed eye to eye.
If you are going off the bitumen then get shockers fitted. That's all you need, that will give the body of your van a better ride. If you are going to upgrade your suspension to handle rougher roads then you need to restructure the body to match the suspension upgrades.
KJB
No matter what you do with the springs , it is so important to use  Shock Absorbers as well  ...otherwise the springs act like a PoGo stick .......
KB
Yes . Leaf springs dont pogo too much . Yes agree shock will help ! Also a better bump stop ! May not even have any fitted ?Built to a price ., ( but the manu spend thousands !!! Pffft ) Long bump
Stops actually act as bump
Control . Only thing to be aware of fitting shocks ? Is to make SURE the attachment is STRONG !!
Yep well, Thanks. Shockies it is. I was thinking of larger diameter wheels to give a bit more clearance. That will waste the new tyres that I've recently fitted, though, so I'll see how I go. We've a trailer manufacturer local so I'll give him a buzz.
Larger diameter, higher profile tyres will also help on poor surfaces.
 I reckon your trailer manufacturer will try to talk you out of fitting shockies. They tend to take the Neanderthal view on shock absorbers. These people still sell off-road camper trailers with leaf springs and no shock absorbers. The owners then wonder why their wheels fall off when they go outback.
The vibrations from the heated black top is bad too !!
