Post Info TOPIC: Removing lamp cover.
I have 2 of these lamps on the front of our Olympic Sprinter poptop, both work with a tap/thumps which to me indicates bad or corroded connection to the festoon bulb.
As I don't want to snap the plastic by levering in the wrong place I wonder if anyone else has had experience in removing the cover to access the bulb.  I have tried gently levering the cover but to no avail. Like most 'snap-on' covers, unless you lever from the right spot they snap.
Any help appreciated
I have never been able to prise the covers off these sort of lights, without breaking them, as they seem to get brittle
I also find, that it is nearly impossible, to buy the exact same light
I measure the outside and either buy a similar one from a caravan or auto shop, or if I have the time, buy about 4 at a time LED type from eBay
KJB
 If only the Catch Tab  breaks use a little bit of silicon to hold the lens . A blade will remove it if needed next time
KB
Thanks for the replies - I might try levering it from the top where it's less noticeable if it snaps and I need to silicon it up. I could also try using the Dremel to grind away the locking tabs and then silicone it back.
Thanks again
Hako.
Sometimes in warm conditions the plastic is not as hard ? Plying carefully in correct place ? Often spray a little olive oil from the spray can helps . A little graphite type grease carefully on connections helps keep corrosion at bay .
I had the exactly same ones on my Road in the Sky Star van, and changed them to led lights, no more bulbs blowing and no more water ingress into receptical or the van itself. Cost including the lights $20 ea fitted.
Ric - The Eccentric One
Maybe it's worth changing the light to a different one, Hako.
IMG_0059.jpgI've ended up using the Dremel to cut away the top clip which enabled me to prise the cover away from the body. The lamp seems in good condition and I'll solder the ends of the festoon bulb to the spring clamps - if that destroys the bulb then I'll solder an LED into the clamps. Not real sure about the earth which is just a self tapper screwed into the aluminium cladding.
Thanks for the help.
Good luck
I'd replace the incandescent bulb with LED prior to setting cover back on with adhesive, - never need to have it off again.
A good idea of Possum's and they would be a better light into the bargain. I would also check the earth wiring at each light and certainly not solder the festoon globe to the fittings. That is band aid treatment. Do it properly the first time and replace the globes with LED if not shout yourself a couple of new clearance lights.
www.ebay.com.au/itm/10-X-Amber-Red-Clearance-Lights-Side-Marker-4-LED-Trailer-Truck-Caravan-10V-30V/264090240602%
And in OZ
-- Edited by oldbloke on Thursday 18th of February 2021 01:16:58 PM
Sta
Yes, probably good advice not to use the old incandescent bulb - I have some white LED's that I can solder in but I'll have to do the other side as well otherwise they will look different. I don't really want to replace the unit as disturbing the seals may cause leaks plus the clear lens is in good nick.
Thanks again.
Good Luck.
