Post Info TOPIC: Fridge and radio
Fridge and radio
Has anybody body had an issue with radio on am and when fridge opens volume drops ?
Another odd question asked in the Solar Power section????? Why not ask in the correct area of the forum ???
Sorry about that my mistake, Hope it didnt take up to much of your valuable time
Fridge and radio on same circuit back to battery?
Probably due to voltage drop at the radio, caused by increased current from fridge.
If this is the case , need to increase cable copper cross section to the fridge. ie so fridge causes less voltage drop.
 I see one response to the issue in over a month. Perhaps a repost in the general part of the Technical forum might put it in front of others that have had your experience with your radio.
Just a suggestion to try and get you an answer.
Regards Ian
