Post Info TOPIC: Dinner ware
Dinner ware
this Q has probably been asked multiple times but I could not  find any recent decussions
doing my homework on accessories for my VW Transporter and seeking advice on what other GN have or are using
dinner ware, storage containers ect
regards Russ
Corelle, the easiest place to get it is from BigW. Just get the number of pieces you will actually use. One extra plate for serving & cutting tomatoes on is handy! Use the smaller bowls & plates as they are easier to store.
We folded up some coreflute & used double sided tape. The boxes had to fit an exact size in our car. The plastic des rub & edges do cut so stuck the loop half of Velcro on key areas & for feet.
Nothing better than seeing the envy on people's faces in remote areas when you have your coffee made from freshly ground beans!
https://thegreynomads.activeboard.com/t65885379/aero-press/
We also have a set of 4 Corelle dinner ware in our van. Excellent product.
Jay&Dee
KJB
Or the calmness and stress relief coming over your own face as you have that first sip ...way out there....!
KB
We also use Corelle, simply stacked in a cupboard with non slip matting on the bottom of the cupboard. Our glasses and coffee mugs are in a drawer with a thin piece of foam on the bottom and another piece of foam about an inch thick on top with circles cut into it that fit each glass/mug. Had it like this almost 10 years, travelled over all kinds of corrugated dirt roads without a single breakage. Storage containers we have a few clip lock plastic containers and also use zip lock bags a lot.
Another vote for Corelle . absolutely hate eating off plastic or melamine .
This is our storage solution.
Translucent plastic boxes that allow the contents to be seen and always where they are supposed to be.
Looks like I will be the odd one out but that's OK. I have been told a few times that I am odd.
I use Melamine plates and bowls but have 'real' mugs and 'real' glasses for those special drinks. I only have two of each item as I am solo so gives me a spare just incase.
I also use clip lock plastic containers and like Meredith use zip lock bags, heaps of 'em in fact. I don't like cling wrap. I also use foil trays to cook in when using my Baby Q which is mostly. Saves on cleaning and water and with a wipe can go in recycle bin. Also saves having heavy baking dishes and the like.
Has worked great fo me now for 9 years all up.
Dougwe, you're not the odd one out as we have Melamine plates and bowls also. For day use whilst on the road we use Thermos mugs - saves putting on the gas and boiling the kettle. Have a couple heatproof cups that we got in the 1980's that are still going strong and a set of those old tin glasses that come in a pouch (vintage ha ha). All food, if not in a tin is in plastic containers, some snap lock, some tupperware and other brands. After a couple of run ins with mice over the years learnt to mouse proof all food stuffs. We have an assortment that fit nicely in our draws and cupboards. You will work out what suits you as you go along. Our motorhome is not fancy and we don't have fancy stuff, but everyone is different and hopefully we are all happy campers with our set ups. Cheers and enjoy.
Check out Vinnies and Salvos for Corelle plates, wine glasses, Nut Cracker (for crabs), flatware, pan/pots and cooking utensils - able to completely set up your new van for about $20/25 - also does some good for the community.
Good suggestion.
We bought a motorhome in Germany a few years ago and did this. Got about 90% of what we needed.
Left it all in the MH when we sold it after 3 years touring.
Plus one for Corelle. Done the Melamine thing but Corelle is much better. Pretty well priced too at Big W. A 4 place set certainly isn't sheep stations.
Greg O'Brien
We use plastic plates . I thought no they are supposed to be disposable type ? But wash them . Noting seems to stick to them ? Wash really easy !!! Carry 4 plates 2 blows, 2 cups . Depending how many are with us ?? Stainless cutlery . One thing we forget was can opener and screw cork remover !!
I don't trust Corelle plates as they are the only plates that have ever broken in our home. In the caravan we use plates and bowls from Palm Outdoor Australia (available at Anaconda stores). They are similar to melamine, but unlike melamine they are safe to use in the microwave oven. They have a built in rubber ring on the bottom so you don't even have to put rubber separators between the plates, you simply stack them and they stay in the one place!
We use plastic tall glasses, wine glasses, and mugs. We use plastic containers with clip on lids for most other storage such as pasta, flour, sugar, etc. We have all our herbs and spices in little plastic containers.
We have built a wooden platform which sits over the water pump under the dining area seating. The platform has a zip up soft plastic container with many compartments on it which stores all our canned and packet goods. This acts as our larder.
Derek Barnes
KJB
We have used Corelle dinnerware in our vans and campers for years without any special packing or storing , basically just the same as in the kitchen at home - cannot ever remember any breaking due to travel  (done some pretty rough roads too - Canning, Simpson, Gulf, Gibb etc...) Good gear - light and tough.
KB
Our 2 Corelle bowls & 3 plates are jammed down the side of our coreflute box, no packing in between. We have been on 1000s of km of corrugated roads, some stone covered. No breakages.
The only thing we have broken is the fake nylon plastic Decor containers. To be fair, it was cold front the fridge & we dropped it on hard ground.
Even our old proper glass vacuum flask has survived (we have a spare)
We just can't stand eating off plastic.
Usually have a set of 4 of everything in Corelle.
Glass wine glasses, 4 dinner plates 4 B&B plates, 4 noodle bowls, 2 large salad bowls, 1 melamite serving tray, 4 bone china coffee mugs. 2 egg cups 4 KF&Spoon 2 tea spoons
We always use table cloths.
Plates stored in wire racks & glasses/cups in wire frames screwed to the wall.
Magnetic knife rack holds 3 or 4 good knives.  Sharpening stones in kitchen drawers.
Full set of silicon kitchen utensils  .. spoon, egg slice etc.
msg
I really hate paper/plastic plates, but, I hate washing up more. So I use them most of the time.
Also, because I often camp remote and water is an issue its a way of saving water. (My rationalisation)
Must have china cups and real flatware though.
Yes I know not good environmentally but...would never leave behind and dispose of responsibly. Costs a bit more but worth it to me.
