Post Info TOPIC: Disc Bowls
Disc Bowls
Hello fellow Nomads
i want to have a set of disc bowls in our caravan to play on our travels. I can only only find one place that sells them in Oz - Disc Bowls International. Does anyone know of any other supplier/retailer that can buy from?
Disc Bowls do have a special to assist Breast and Prostate Cancer www.discbowlsinternational.com/wp/wp-content/uploads/2019/06/Pink-and-Blue-Flyer.pdf
I would imagine that any GN that has a timber lathe could easily turn up a shaped set. Failing that, I have noticed a few nomad teams playing with flat discs, any Men's Shed would be able to knock up a set or two for a contribution to their cordial fund.
maybe someone can enlighten the uninitiated amongst us, as to just what this game is?
Graham Day.
Not all those who wander are lost.
Good game once you have had 5 or 6 refreshments
-- Edited by Craig1 on Saturday 27th of March 2021 01:37:42 PM
Cheers Craig
Read rules here; caravanclubsqld.org.au/WP-misc%20documents/2013_Disc-Bowls-Rules_State.pdf
Comes up as error404 possum, is this a game you can adapt for 12ga shotguns like skeet say?
Its a long copy and paste but here are the rules.
1. The equipment used by the players consists of twelve discs, a kitty and an arena:
a) The discs are approximately 180 mm in diameter and 18 to 20 mm thick, made of wood or
plastic, with one edge rounded and the other square. Both sides of the disc may be slightly
wasted to provide a rim for better grip. The weight of the disc is between 290 gms and
310 gms. A centre hole may be cut or drilled to obtain a near correct weight. (If discs are
made from MD fibreboard to the above specifications, the weight will be approximately
300 gms.) Each team has a set of six discs (i.e. 3 discs per player) all the one colour, which
must be a different colour from the opposing teams discs.
b) The kitty is a ball, preferably white, approximately 75 mm in diameter and 155 gms in weight,
e.g. a hockey or cricket ball. Often a lawn bowls jack is used.
c) The arena is a rectangular area, 9 metres by 3 metres, placed preferably on a flat, grassed
surface. Each arena is defined by thin ropes, with markers at 4.5 metres along each long side
of the rectangle, to signify the halfway point of the arena.
2. Players:
a) The game of Disc Bowls is played with two teams, each team having two players. Any two
people constitute a team. Each team has a Skip and Lead. The Lead plays first.
b) The Skip and Lead must not swap once the game has commenced. If a player plays out of
turn, the disc played out of turn is removed and is not counted in that end. However, if the disc
thrown out of turn has changed play to the advantage of the team whose member threw out of
turn, the end is replayed.
3. Officials in a competition:
a) Control of the competition Appointed officials make up the official draw, set game times,
call up players when they are required for a game and maintain a combined scoresheet for all
games. Note: If player(s) fail to report for a game within 2 minutes, the team is disqualified and
their opposing team automatically wins the game. All games are played under the control of
the Competition Referee(s), whose decisions are final.
b) Control of each individual game Each individual game is controlled by a Marker, who
chooses the end from which play commences. At the finish of each end, either the Marker or a
separate Scorer records the points on the game card.
4. Game Outline:
a) The purpose of the game is for each player to throw three discs so as to come to rest within the
arena as close as possible to the kitty. The team whose disc(s) in the arena are closest to the
kitty wins the end. Each game consists of five ends, except the semi-finals and final, which
consist of ten ends each.
b) The game commences with the Marker tossing a coin or disc with the two Skips. The winner of
the toss chooses the colour of the discs they wish to use and either elects to throw first, or asks
the opposing team to lead off.
5. Playing Each End:
a) When rolling the kitty or throwing a disc, the player stands outside the arena (the narrower end)
and between the two sidelines. If the player's foot/shoe is outside the sideline or over the end
line when throwing a disc, the penalty is removal of the disc. However, if the foot fault has
changed play to the advantage of the team whose member threw with their foot out of line, the
end is replayed.b) The Lead of the team playing first rolls the kitty into the arena. The kitty must settle past the
halfway mark and within the arena. If the kitty does not roll clearly beyond the halfway mark or
rolls out of the arena, the Lead of the opposing team then rolls the kitty, which must settle over
the halfway mark and within the arena. If both Leads fail to roll the kitty correctly into the
playing area, the Marker places the kitty centrally in the second half of the arena.
c) Whoever rolled/placed the kitty, the Marker centralises the kitty between the two sides of the
arena. If the kitty settles less than one metre from the far end of the arena, the Marker places
the kitty at the one metre position.
d) The Lead who rolled the kitty first then throws the first disc, so as to come to rest as close as
possible to the kitty. Play continues with the opposing Lead throwing a disc, followed by the
first teams Skip and then the opposing Skip and so on, until all twelve discs have been thrown.
e) If a disc or kitty comes to rest either within the arena, or on the rope of the arena (if any part of
it is in contact with the rope), it is deemed in play. If a disc exits the arena and then re-enters,
coming to rest within the arena or on the rope, it is still in play. Any disc that come to rest
outside the arena may be immediately removed by the Marker so that the disc cannot
confuse/hinder play. The Marker is the judge in these situations.
f) To start the next end, the winning Lead of the previous end rolls the kitty and throws the first
disc from the opposite end of the arena.
6. Scoring:
a) At the finish of each end, the Marker, in consultation with the skips, determines how many discs
of one team are and closer to the kitty than the nearest disc of the other team. The marker
awards one point for each disc in the arena of the team whose disks are closest to the kitty.
For example, if Team A has 2 discs that are closest to the kitty and the 3rd nearest is from
Team B, then Team A is awarded 2 points and Team B nil.
However, if there is expressed doubt by either skip, the Marker shall measure with an accurate
measuring device any disc that is not obviously closer to the kitty than the other teams disc. In
this event, measurement shall be taken from the kitty to the edge of the nearest disc.
The Marker's decision will be final in all matters of dispute; however, any point of contention can
be referred by the Marker to the Competition Referee.
The Marker or a separate Scorer writes on the scorecard the number of discs within the arena
of the team that are closest to the kitty before the nearest disc within the arena of the other
team.
b) If a player knocks the kitty out of the arena with a disc, the other team automatically wins the
end and is awarded three points for that end.
c) Where one or more disc from each team is in contact with, or the same distance from, the kitty,
that end shall be a tie; i.e. it is a scoreless end. The Lead who started the tied end leads off the
next end.
d) At the finish of the game (i.e. all ends have been played), the team with the highest number of
points totalled from each end in the game is declared the winner of the game.
e) However, in the event of a tie after the final end has been played, the Marker places the kitty
centrally in the second half of the arena, and tosses a coin/disc to see who throws the first disc.
The winner of the toss chooses who plays first and an additional end is played to provide a
winner of the game.
f) When the game is finished and all scores are agreed, the Marker or Scorer brings the
completed scorecard of the game to the appointed official(s).
Having a lathe, keen to make a set with flat side, bias side etc., like as in lawn bowls, being keen to have a cheap outside activity with not much gear to carry, I looked into disc bowls.
What a shock I got to find it was really disc throw!
I felt totally ripped off!
Still we have "Klop" to use or even Bush Petonck (Sp?) using what ever rocks are to hand where ever we end up at days end.
Cheers - Ian
I slowly realise as I get older that I am definitely NOT the fastest rat in the race.
Also the older I get the more I realise I do not know.
Much more fun throwing a Frisbee to a Border Collie and marvelling at there dexterity or to actually throw it to another person, children are the best for laughter and amusement, their amusement at you trying to catch it, nothing better on this earth than children laughing.
Kebbin
 I agree :)
