Post Info TOPIC: 6 Wheeler
6 Wheeler
Have been looking at Six Wheeler Conversions in Toowoomba as they convert a lot of different 4x4 vehicles to 6 wheel vehicles whilst still being 4x4 drive.Wondering if anyone has experience with any of these vehicles and your thoughts and recommendations please.We would only consider going up to the 4495 gvm upgrade as my lady would also be driving but only has a car licence.Thanks Ian
Ian Hodges
Good for increased load capacity but can have a reputation for increased tyre wear (and probably fuel consumption).
They do have a significant detrimental effect on off road performance.
I think the Mercedes 4X4 cab chassis is 4496kg GVM straight out of the showroom, expensive but so is a 6WD conversion.
 Hi Ian....it first needs to be asked what you are hoping to achieve? Are you looking for huge carrying capacity,are you wanting to tow a van,and where do you plan to travel? Be aware that 6 wheel conversion on a 4wd vehicle will severely limit off road abilities,because of weight carried by the "lazy" axle.You have been considering a DMax,judging by your previous threads,and I believe that that vehicle can be upgraded to 3600kg GVM,with an upgraded rear axle rating of 2150kg,and front axle at 1450kg? Another regular contributor to our forum managed to get a new GCM rating of 7000kg on his DMax,which means that, realistically, that car and van could be loaded to around 6600kg,if axle weights were perfect,which they never will be.Even if you can get to only 6300-6400kg GCM,this gives a pretty impressive vehicle,considering that an unmodified LC200,for example,maxes out at only 6550kg when towing 3500kg at 10% towball weight.....and that,once again,is only when it is loaded perfectly on all axles.Cheers
-- Edited by yobarr on Monday 2nd of November 2020 12:00:43 PM
x2 for PnM, yobarr,
hodgie, would your lady be comfortable driving something that heavy?
You will only be getting a 4x4 with a lazy axle or are you after 6x6, all wheels capable of driving?
I'd be frightened of the cost of the latter!
If you are planning to do that, why not just buy a 76 series Land Cruisier, jobs done.
-- Edited by iana on Monday 2nd of November 2020 12:28:53 PM
I know of some 6X6 Landcruiser conversions purchased by a Government department for use in remote areas.
They were described as "dogs" in the bush by the drivers.
 Nice thought,Ian,but the 76 is way too short in the wheelbase,at 2730mm,and has a GVM of only 3000kg,and GCM of only 6500kg.Probably best to go for a 78 series (Troopy) or a 79 series twin-cab if you need passenger carrying ability.Otherwise,the indomitable (?) 79 series ute. All these latter options have the all important rear axle capacity of 2300kg,which means that,unmodified,each has the ability to reach 6450kg loaded weight. Cheers
P.S Each one,however,has a clutch pedal!
Warren-Pat_01 wrote:
x2 for PnM, yobarr,
 Absolutely...I won't mention any figures,for fear of causing somebody to suffer a heart attack,but you may well need to sell the house to finance the upgrade! Better to just buy a suitable vehicle in the first place,me thinks.Cheers
There's a crowd in WA (don't ask me where) doing a chassis extension on 76 series Land cruisers, I didn't know why until now, could be the better option though.
 Interesting! It'd be a weird looking vehicle,surely,as it is actually a station wagon.How would they extend the body,I wonder,and will they be putting a better rear end...springs and diff...into it? Worth watching perhaps,but it would have a limited market,I'd think? Cheers
My mistake, I mean the tray flat top. On that note I remember reading that the turning circle is further reduced, not good for bush work.
-- Edited by iana on Monday 2nd of November 2020 01:47:05 PM
Yeah,I was wondering about that! You refer,of course,to the VDJ79R,which has a 3180mm wheelbase,a 2300kg rear axle,and GCM of 6800kg. The turning circle is huge,but you soon get used to that,and the vehicle will do some amazing things in its standard form.Rides a bit rough,and doesn't have too many flash gadgets,but unbeatable in the bush,and for safely towing 3500kg.Cheers
This 1995 Toyota camper was purchased by my sister and BinL.
Originally it had a wheelbase of 2950mm and a GVM of 3035kg. The axle limits were 1300kg and 2500kg.
The chassis extension to 3550mm (600mm) was done in Victoria in 2000 before they purchased it and brought it to Adelaide.
They had an engineer in SA check the chassis extension and increase the GVM to 3800kg (the total of the axle ratings) in 2014.
It is possible that it will be on the market soon.
-- Edited by Peter_n_Margaret on Monday 2nd of November 2020 02:58:23 PM
My friend put an extra axle on his dmax as he bought a new van  around 3500 kg and he had everything on his dmax so it was his only real option.He lives in qld and can not get a gcm upgrade in that state.You might be better of with an upgrade or go with the 79 single cab which will give you a gcm of 6800 kg without any upgrade and Australia wide rating on gcm .There are drawbacks with a six wheeler,no good in sand ,the 25000 cost ,sqeeling tyres when turning ,more tyres to maintain ,longer vehicle never for me
JB scorpion sting 206
if you go to youtube " trip in a van " they have had the conversion done with the gvm/gvc upgrades, the cost i do not know but they seemed to have spared no expense
https://www.youtube.com/watch?v=dk9sl2f9eQw&t=170s
 Mate has one...I will look at your video when I get a minute.Cheers
Thanks for replies.We are either going with Dmax or Bt50 which with the conversions they do in Toowoomba take vehicles up to 4495 gvm which then allows you to have a reasonable size van which we do want as we are hoping when the virus and everything settles down to be able to travel around Australia on a full time basis.Hoping to mainly freecamp and get out and enjoy the bush.We think the conversions are around 25k which includes new tray etc and compliance plated so we think it is maybe looking into as the last thing we want to do is be over loaded and have all the troubles that go with it.
Ian Hodges
there are a few videos the one listed is the first . they show the process from start to finish
Although it was a long time ago and they could well have made improvements in suspension set ups, my brother had a transit tray back with a lazy axle added, and although it carried well it was absolutely useless on any sort of uneven ground as the lazy axle would lift the weight off the driving wheels. As I say there could well have been improvements in this area and having 4x4 will help but keep it in mind when you are looking around. Landy
Hi Hodgie55,
I haven't read through all the posted replies and understand the conversion will take you up to 4495Kg Gross Vehicle Mass.
I have seen photo's of all light trucks bending even Landcruiser due to dynamic loads placed on chassics by overweight or incorrect loading, not saying it will, just saying if towing a large van is the goal.
Were you to just buy a RAM 1500 Express @ $79,950 drive away you can tow 3787Kgs and still have 845kgs payload and save on fuel or buy a used RAM 2500 with 913kgs payload & tow 4500Kgs and save on fuel.
My Ram 2500 from NSW to WA empty used 9.1L/100 and return towing 3200Kgs returned 14.7L/100 keeping to speed limits were road conditions allowed.
I am pretty certain Isuzu or Mazda won't be warranting anything on the Truck once they're converted.
Ram man with a Van
Ram Man wrote:
Hi Hodgie55,
Absolutely forget the RAM 1500 if you plan to tow much more than 3000kg ATM as a PIG trailer. (Caravan).The rear axle is rated at only 1770kg, which is less than the rear axle capacity of the current range of popular twin-cabs.There is NO chance of towing much over 3000kg,assuming 10% towball weight.....and that's with nothing in the tray. The RAM 2500 is a vastly superior vehicle,if you are looking at those types of vehicles,but I don't understand why the OP appears obsessed with attaining 4495kg GVM on a 3 axle,6 wheeled,4x4 ute? Trying to tow 3500kg offroad with such a vehicle will very quickly see it all end in tears.What weight he plans to carry is beyond me,as I have everything I could possibly need to free camp for extended periods,including 600 litres of water and 200 litres of diesel,in my car and van,total weight 6800kg,legal on all axles. Anyway,we can only give advice,in an effort to help,and I wish him well,whatever his final choice.Cheers
-- Edited by yobarr on Wednesday 4th of November 2020 12:55:20 PM
Hi Yobarr,would you please tell me what sort of vehicle and caravan you have to be able to achieve the figures your talking about.I'm completely new to caravanning and don't even have a caravan yet and trying to find out as much information as possible.We currently have a Mazda bt50 and trying to assume we keep what we have it would be good to get an idea what sort of weights legally we can handle and trying to be cost effective as possible.
Ian Hodges
We are also hoping to buy a good brand offroad caravan as we intend to free camp and know that they are fairly heavy and wont have a lot of capacity for carrying everything we want to be permantly on the road.So trying to lok and access all options available to us before we start.
Ian Hodges
To me (wish full thinking), its a dual cab tray top Land Cruiser. I have a BT50, and that LC will give me another 1/2 tonne CVM. Plus it's built to go bush without mods. But ATM can't affrod, have to win Tats first. PS we are full time in the van.
Just a note, any vehicle you spend money on, or modify, you won't get that money back at resale, how ever every farmer and out back tradie is after a flat top cruiser.
Ian
 Hi Ian....Your comment "I'm completely new to caravanning...." finally helps me to understand your apparent obsession with a 4wd 6 wheeler. Bluntly,forget it,or you will incur a mile of pain,particularly financial.These vehicles may be fine for bitumen,and possibly limited types of well formed metal roads, but are not at all suitable "off road".....even "free camps" will be off the menu if it rains.Been there,done that.Your current BT50 will be able to safely handle a van up to a maximum of 3100kg GVM,and would be a good vehicle to tow such a van.Since you are new to our forum,I will briefly explain your weights.Your current GVM is 3200kg,and your GCM (maximum legal weight on wheels of your car and van) is 6000kg.If you carefully load your car and van you will have 1350kg on your car's front axle,1850kg on the car's rear axle,and 2800kg on your van's axle group.(GTM if you like...gross trailed mass).Majic! 6000kg,and a nice safe unit! Of particular importance,the car is thus around 14% heavier than the van......having the van around 10% heavier than the car is very important if safety is of any concern,as this helps to minimise the chance of the "tail wagging the dog".You would have towball weight of 300kg,or the generally accepted 10% of ATM.My car is a 79 series Landcruiser,V8 diesel,and I have made an inexpensive increase in GVM to 3780kg,simply by combining the factory axle weights.(1480kg front and 2300kg rear) to allow me to to safely run at my factory GCM of 6800kg.Front axle is at 1350kg,rear axle on car is at factory rate of 2300kg,and weight on van's axle group (GTM if you like) is 3150kg....and no WDH! Although mine is a single cab model,the 79 also is available as a 4 door ute if you need to carry passengers.I fitted an aluminium canopy to mine,high enough to sit up in bed when not towing the van,and I have covered the water options too.There are 2x60 litre water tanks under the tray,and on the roof I have a 70 litre black-poly tank for hot water if we don't have the van in tow.Many criticise the 79 as being dated,ugly, uncomfortable and many other things that,to me,are of little importance.Nothing compares or competes.Within about 3 weeks I will be passing through Gatton on my way to Western Queensland,and then the NT,so I would be happy to drop in to help you if you wish? Alternatively,you might like to send me a PM with your phone number? If you are unfamiliar with how to send a PM (private message) you simply click on your user name ait all will become clear! To this end,I will send you a PM now,so you only have to click "reply". Cheers
-- Edited by yobarr on Wednesday 4th of November 2020 03:04:19 PM
Hi Ian,
Maybe something like this would suit -
https://www.caradvice.com.au/892709/2020-volkswagen-amarok-xxl-review/
Nev
Buy an old Land Rover Perentie 6 wheel drive.
Hi Jonathan....Whilst I suspect that you're being mischievous,these old bangers wouldn't. pull the skin off a rice pudding.To me,that vehicle looks well overloaded,even without any towball weight.Gotta be close on 30 years old,too? Possibly good for off-road adventures,similar to those undertaken by Peter'n'Margaret,but useless in this situation! Cheers.
Nevd wrote:
Hi Ian,
Nev
 Hi Nev....whilst this Amarok undoubtedly is a great vehicle for some applications,it is entirely unsuitable for what the OP,Ian,is trying to achieve. The problem is that the GCM remains at only 6000kg.Were Ian to hook-up to a 3500kg van,he would be instantly over his GCM...without even a driver!   Figures are:- 3500kg ATM van with generally accepted 10% towball weight (350kg) leaves 3150kg on van's axle group.(GTM if you like).Car's kerb weight is 2281kg BEFORE chassis extension,and before the 230kg tray is added,so we now have a car that weighs over 2500kg,and we are over the 6000kg GCM before bullbar,towbar, luggage,tools,water etc....and still NO DRIVER or passengers,and no towball weight either! Additionally,the van would be around 10% heavier than the car and an accident looking for a place to happen! Put bluntly,there is no way that any of the current crop of lightweight twin-cabs can be modified to safely tow 3500kg as a PIG trailer without also getting a GCM upgrade.Cheers
-- Edited by yobarr on Friday 6th of November 2020 09:04:08 AM
