Post Info TOPIC: Toyota Coaster 2004 12v converter
Hi,
Does anyone know where the 12v converter that feeds the radio is in a 24v 2004 Coaster is located?
Thanks, Kevin
my coaster is 1987 and is just under dash right in front of gearstick, most likely no help to you
blaze
-- Edited by blaze on Sunday 1st of November 2020 08:08:51 AM
It might not have one the radio could be 24v, have you checked voltage at the radio?
 Radio is 12v.
G'day Kevin,
Do you know what else in your bus runs off 12v?
I had an '81 MQ Nissan Patrol diesel - there was no 12v converter supplied; they (Nissan) just ran the 12v accessories off one battery (not so nice). I built a 24v/12v converter which ran for several years until we drove across the Jardine River. Unfortunately my silicon sealant wasn't perfect, it filled with water & didn't work too well after that! I mounted it behind the RHS headlight for cooling reasons, hadn't banked on "water cooling".
So from then on, I reverted back to Nissan's original method. Only the car radio/cassette player & CB radio ran off this 12v feed. It worked for another 8 years until we traded the car.
I also recall a system of resistors that Hella produced at that time to "safely" split the batteries. I may have something at home still (stuck in Toowoomba with health issues). If I remember, I'll look it up later.
If the converter is a linear type, then it will dissipate as much power as it delivers. It would be MUCH better to replace it with a switchmode type.
