Post Info TOPIC: Speedo not working
RE: Speedo not working
Hmmmm. Only takes 10 to 20 mins to replace pinion gear and slot it back in. Il try that first and if speedo works problem solved. If not then il pull whole cable out and also check speedo cable at dash end.
1988 Nissan Civilian
We used to put cable at gearbox end in electric drill and run at low speed - to test.
Now that's a good way to go about it! Might give that a go once the rain eases up so that if it's not the pinion gear then I can start on on other things to fix it.
thegreynomads.activeboard.com/t62383101/calling-any-gq-patrol-owners
Check for dry solder joints at the crystal.
Hi tuggersbmx
As a bottom of the barrel idea, which may be expensive
If you find that your only alternative, is to obtain a 22 tooth speedo pinion gear, and if you can not wait for one from Japan
You could ask around at a machine shop, if they could make one for you one
Hi Tony Bev Cheers for the input. It all helps. I have a 21 tooth pinion gear on its way from VIC. Will replace by the end of the week and hopefully fixes the issue with the speedo only being 4.5% out. Then get once j get engineer cert I will also have a gps speedo hooked up. If the pinion gear does not fix the issue I have more tests to do to figure out if it's the actual cable or even the gear at the speedo / dash end. Cheers Mick
 Ha!   It's that long since I last did that (on my old Vanguard) there were no battery drills.  I used one of those old 'egg beater' type hand drills.
BTW I saw them still for sale in Bunnings .. even had a choice of two models.
You guys are old codgers ! Unfortunately I know what your talking about !! Lol
starting to sound like an antiques road show. i also know what they are talking about so what does that make us
Great memories!! We still have it !! Our children may have different opinion ? Lol
Speedo is all working fine now. Just a few % off. So all is fine.
