Post Info TOPIC: Speedo not working
Speedo not working
Hi everyone. 1988 MGW40 ED33 Nissan Civilian Trying to get my last final things done for rego and one thing that has got me stumped on the speedo is not working. It was a few months ago then just stopped. No blown fuses. I've heard that if that speedo fails then it could be a faulty cluster unit? So I may need to pull the whole thing out and replace? Has anyone had this issue? Could it be something else? I've got a full spare bus to switch out parts and will be hooking in tomorrow but looking for advice if it could be something other than faulty cluster? Cheers Mick
1988 Nissan Civilian
KJB
Try running a new temporary "dedicated earth" to the cluster....
KB
It would still have a cable drive speedo wouldn't it, check the cable if it has one.
blaze
Yeah I believe it has a cable run speedo. Temp Earth I will try if possible. Il pull apart dash tomorrow. See how I go. If I can't solve il let ya know. Cheers
mostly the square drive on the cable get rouunded corners and wont drive, Gearbox may have a right angle drive that the cable srcews onto, check the gears, often plastic/nylon and they strip.
blaze
Both my previous cars, a Peugeot 504 & Seat Ibiza, did over 250,000 km. Both their speedos died. With the Seat I knew the speed of the car from the tacho in each gear & had a little chart just in case I forgot.
 Hi Micksmile
If it has a cable drive which I also think it will have, just swap the cable from the other bus for  start. There is no electricity in the speedo meter that makes it work just the cable going around (or not !!)
On my cars the cable had worn to some degree but something in the back of the speedo had worn out, as the cars were so old it was not worth replacing.
First thing il be doing is swapping over cable from parts bus to road ready bus. The rego inspectors / engineer (who I need to get a certificate off before I get rego) won't give the bus a pass without the speedo working. Pricks. Unless if I can't fix it I might be able to get some sort of digital one and calibrate with GPS. Mick
Engineer isnt a P#*ck as you put it he has to put his name to the work you have done , i would want it right if my name was going on the paperwork too .
KJB
There are plenty of Digital / GPS style units on eBay for under about $50 . Cheap, easy to install and clear display.  They may be the answer you are looking for.
I have seen these used in Hot Rod conversions and motorcycles. Personally I cannot see why they would not be legal , they are current modern  technology. Worth checking out.
KB
As said check inner cable ? I have fixed with hammering cable square again and re oiling / greasing . If elect ? Change the transponder .
Will hopefully have a chance tomorrow morning to inspect a bit. I've got a spare cable so that will be first option to repair. If no go then will look at electronic replacement. See how I go tomorrow. Cheers
 Micksmile
That's a bad attitude saying that. The rego inspector is just doing his job as he is required to do to certify the bus is roadworthy. I am disappointed to hear you call him a prick. That sort of attitude is what has caused the virus explosion IMHO.disbelief
He's not really a prick. I know he's doing his job and I'd actually prefer to know my build us safe ECT.
Just made everything more expensive and delayed my build for quite some time. It's more that rego requirements have changed in Canberra now and other state mod plates are not recognized. The bus was already engineered to be a motorhome in new but I've had to do the whole process again. So it's just been a pain in the butt.
Engineer is just doing his job. So are the rego inspectors but they can be wayyyyy over picky in Canberra.
I got around to pulling out the speedo cables at gear box end. They seem different first. Pictures attached. One with the gears on it is the one I need to get working. As you can see from the pics the gear is pretty worn out which would most likely be my issue of no speedo working.
Unless the other one which just had the one slot at the end of the cable need to pulled apart further in the gearbox to access the same type of gear ending? But I cannot find a way to pull anything more off.
Also I need to jump back under the bus with the gear ending to see how to remove the actual gear ending itself. Hopefully just a c clip or something. The gear would not just simple pull out.
Would a replacement gear shaft from a patrol possibly work?
Cheers for any help guys.
Once again you are right about the engineer not being a prick.
I think that gear is matched to the diff gearing so the speedo reads correctly.
Home is where I park the rig.
Tug 2016 D-Maxine
Den 2009 Goldie RV
Hi stretch. Yeah I've just researched and that is correct. So in my eyes the one from my other bus with different ratio diff won't work anyway.....but I still couldn't get the metal sleeve that plugs into the end of the gearbox on the FD33T removed. I could get the cable out but not the sleeve that holds the gear pinion. Il order a new gear pinion for the ED33 and buy a digital speedo as well. Cover both sides of things.
electronic is ok but I believe gps based speedo dont meet ADR. It would pay to check before buying
blaze
Mark your rev counter to speed on
GPS . May not be engineered acceptable? Can calibrate Speedo by redoing speeds on
Gauge also ! If changing speedo gear is an issue ?!
Theres always equal & opposite reactions !
I cannot find a 22t speedo pinion to swap over ANYWHERE! Japan is 6 weeks wait plus with covid probably longer. Most likely 3 months before I get it. I found a purple 21t pinion in Australia which I could swap over and I believe it would put my speedo out a tiny percentage? Maybe 2 or 3. Engineer stated my speedo needs to be within 5%. I'm thinking purple pinion swap over plus gps speedo as back up and he should pass me on that. Fingers crossed.
Thats where you can change the speedo numbers to suit !
If you use the 21t pinion you will be out by 4.55% either over or under reading depending if pinion is on driven side or driving side of speedo mechanism - If there is no GPS to compare it to the engineer doing blue slip would most probably be unaware of discrepancy (unless he is told).
Aus-kiwi.
Change gearing at speedo end?
So if I go down one tooth at gearbox end and engineer complains that it's not right should I go up or down a gear / or two at cluster end?
I won't install gps unit and hopefully it goes un noticed.
One more question.
On the speedo cable where I can replace the gear pinion. ( Too one gear smaller) it looks like there's a pin that holds it in place. I would assume it just knocks out? But don't want to go knocking it if it's supposed to screw out?
If that is a slot up the side and hollow through centre of the pin then its a spring pin. Don't know their real name. Just use pair of pliers on protuding end to close gap and it should just slide out. Bit different to the holdens and tojo l'm use too.
Tug 2016 D-Maxine
Den 2009 Goldie RV
They are called Roll Pins and should be pushed out with a mandrel.
Righto then. Cheers. Il be onto that once the rain stops. Slot the new pinion in and hopefully should be all fixed. Fingers crossed.
have you checked the cable yet, could also have failed.
blaze
What's the best way to check cable? Spin the pinion at the gear box end and have someone sit on cab and see speedo needle moves at all.
remove and inspect, after you take the drive off the bottom it will most like just pull out from the top
blaze
