SmartBar
Post Info TOPIC: grey water tank cleaning
Can we use draino to clean out the grease in the pipes and tank without causing damage?
A.Molenaar
I just use Milton. Has worked for me for 6 years now. Once a year job.
bgt
Put some dishwashing liquid in and go for a drive.
We use a strong solution of Pine O Clean and hot water.
thanks you ever one.
A.Molenaar
DrainO works for me. I let a small amount sit in the sink S bend for ten minutes, before a good tablespoon followed by a couple of litres of water and a good slosh around. Alternative is a Dishwasher tablet.
Iza
Iza
The 30%+ Nappi San type solutions we use in the loo also does a great job on our Grey Water tank, especially if we drain it and drive a few k's to slosh it all around.
Cheers - Ian
Cheers - Ian
I slowly realise as I get older that I am definitely NOT the fastest rat in the race.
Also the older I get the more I realise I do not know.
I use nappy San / percarbonate of soda in both tanks . Once is while I fill with warm Washing machine water with added commercial engine degreaser to get any fats, oils cleaned . Often leave it in there 1/4 full till I empty at next dump
Point . Keeps the pump impeller clean . Try to park on angle where outlet is so it empties properly . Often the last bit has the solid grey matter !!
Same as Aus-Kiwi above
We always try to avoid, allowing food scraps, to go down the sink, by firstly wiping the dishes with a paper towel, before washing them
We use Napisan or Boost occasionally
We mix the Napisan/Boost in warm water, until it is diluted, and then pour down the sink
If you do not dilute the Napisan/Boost, then the granules may clog up the Hevpo (one way) valve, in the drain pipe
