Post Info TOPIC: fridge defrosting
fridge defrosting
After 3 days parked up the fridge stopped working and defrosted. when we got home plugged in the power fridge worked fine. Is this usual.
We"re on the road to nowhere and looking forward to meeting you there
Status: Online
Really might help if you told us what fridge you have.
Very thin on data to go on!
how many times did you open the fridge while away & at home?
How humid was it while away & at home?
How low was the voltage ? 3 way or compressor ?
 Hi patmc49
To answer your question, on all the caravan type fridges I have had, it was not normal for the fridge to stop, unless something was wrong with it
As others have already said, if you give the name, type, and model, of your fridge, the techies may be able to help
By the sounds of the original poster, the fridge was operating on 12V (beit auto or manual setting) as they were travelling. When they stopped suddenly the 12 V supply disappeared. Maybe there is an isolator in the car's power supply for the van? It is most likely a 3 way fridge because it runs on 240 V (if it was a 12 V compressor fridge, it probably won't go on 240 V either). Connect it to 240 V and it goes. A few days later and the tug's battery is still not flat, so I reckon it is the 12 V supply in the tug or the 12 V element blown in the fridge.
