Post Info TOPIC: Battery Longevity
Battery Longevity
I have just replaced the battery in my Mothers Toyota Starlet. Interesting to note the battery was purchased and installed in 2006, ie 14 years old.
It was still starting the car but was getting slower to start. I took it out, put the meter on and it read 12.6V. Put the charger on for 24 hrs and after settling time(12hrs) it read 12.8V. For all intents a fully charged battery.
So thinking about the long life and why, the pattern of use is pretty regular over the years, (creature of habit), the car being started on average 4 times a week and mainly used on short (10 minute max)  trips. A longer trip of around 30 minutes on occasions.
 My guess is this useage (charging regime) is exactly what the battery required to keep it in good condition, plus of course a quality battery to begin with, made in Aus.
Has anyone else had as long or longer life from a car start battery?
Chris & Sharyn.
Tea Gardens. NSW.
I have a nine year old Kia Cerato SLi - it still has the original Korean OEM battery. I only have a few minor non-starts if the car has been left for more than 2-3 weeks without starting - then I use a Smart Jump Start, to kick it over, then it all works normally again. Can't think of the name of the Korean battery.
Vibration, heat, abuse are three things that kill batteries.
The best I did were the batteries in my first Patrol (MQ & 24v). They lasted six years.
Batteries for black top driving are like tyres.
They wear out when being used and they deteriorate with age.
It depends which gets there first.
Off road vibrations from corrugations will kill wet cell batteries. I have killed them in 2 years.
I use AGMs for cranking and have had them last 9 years.
Couldn't tell you how long mine last as I replace it at 4 years. Too much effort wasted with the inconvenience of a stuffed battery.
Hi smile
It has been my experience over many years that battery life is very variable. Some batteries seem to go on and on with normal use and others can just quit one day for no apparent reason. In between are the average ones. So treat your batteries well, do not let them get down too far, use a battery minder to keep them charged if you do not drive much, and hope you got the long life one. aww
I find that having a solar panel with a good regulator keeps the batteries fully charged whether using the MH or not. I replaced the vehicle battery recently as it was more than 6 years old and was in there when I bought it. Still starting OK but we were going away and I cannot be bothered worrying about whether it will start when we are away.hmm
On my car which was used regularly most days the battery just had a cell fail one day. Still started but obviously not instantly as before. My learner driver even noticed the change.  Why did it fail at 4 years, who knows. But it does have variable voltage control so is not kept as fully charged as in previous times. Hmmm is this progress ?confuse
My neighbour's Honda's battery lost one cell at 3 years. I was shocked at how small the battery was. Reducing weight maybe!
bgt
It's not all about charge/volts. Keep in mind CCA. Our RAM was in top condition when the battery simply wouldn't turn the motor. Had plenty of volts on the meter but not enough to turn half a ton of engine over.
 It may have seemed to be in top condition, but it clearly was not.
A CCA test is also useless for checking the capacity of a deep cycle battery.
15 years for my 2001 Vitara, and then sold vehicle, did not replace it before I sold it. It too was a smaller battery.
-- Edited by Bicyclecamper on Sunday 8th of March 2020 01:53:35 PM
Ric - The Eccentric One
 Do you know what make it was? Was the car used regularly?
Chris & Sharyn.
Tea Gardens. NSW.
About 8 to 10 years here . Too scared to say as it often brings on bad luck ! Seems every time I praise anything . Bang !! Years ago a neighbour asked how good was my hay bailer . I said great hardly cost be a cent . Next minute bang !! When its funny but not !!
My wife's 1997 Subaru had it's last battery replacement in 2000. It's starting to get a bit slow in the cranking department now though. We've never really thought about it until this thread. It's probably getting on towards time for a new one though.
Mark F...
VK3KW
2010 Outback Campers Sturt
http://jandmf.com
 That's a great battery life Mark, can you let us know what brand it is?
Chris & Sharyn.
Tea Gardens. NSW.
Mine is like that too !!
It's just a common or garden Century. All it's life I've only ever topped it up with just plain tap water. It's been run dead flat a number of times too. In short it hasn't been treated properly but it's lasted...
Our camper batteries are still going as new and they're Full River and the tug batteries (crank and aux) are both Century.
Mark F...
VK3KW
http://jandmf.com
Always found century batteries do outlast others. For heavy outback use consider a marine cranking battery, built tougher.
