Post Info TOPIC: My Latest Disaster
My Latest Disaster
I have had the van in storage for the last couple of weeks whilst I did a few jobs around my poor old mum's house. (Mum turns 100 in 3 months).
I collected the van this morning and reconnected the battery. I am sure I put all the yellow leads onto the terminal and all the red ones onto the red terminal. I tried the lights and the fridge on battery and all worked. I then set off to the caravan park and plugged in to the mains power. Absolutely nothing but the lights still worked and the fridge would run on battery or gas but not 240 volts. Power points do not work on 240, no lights on battery charger.
I checked the mains power and the lead with an electric drill and it worked so the mains outlet is ok and the cord is ok. I had a park worker check it also and the result was the same. He checked the trip switch and it was on. I cant think what I would have done to blow fuses but because that is an operation to get to and then I probably wouldn't know what to look for, I am at a loss.
I have contacted an auto electrician that I have used before and he will be coming tomorrow morning. Any idea what it might be? It has worked perfectly except for a time when I plugged in a 1000 inverter and blew a few fuses. Like most things, I have no idea about electrics.
Thanks in anticipation. The joys of caravanning.
-- Edited by DMaxer on Monday 2nd of March 2020 07:00:57 PM
Congratulations to your mum, DMaxer
I am not an electrician, but what happened to me was
When the trip switched, at the box (stopping the 240 volt electrics)
I switched every 240 volt electric appliance off
Reset the trip switch, and turned everything on, one at a time, until the switch tripped again
For me it was the 240 volt element, in the hot water boiler, which had tripped the switch
I suppose that after being in storage for a number of weeks, it is possible that the mice have nibbled through some wire insulation
Hope that a licensed Electrician can get it sorted for you, as an auto Electrician, usually only works on 12 volt stuff
Thanks for the insight Tony. The electrician came out and went through all the processes from the mains to the inlet and then through each of the appliances drawing 240 volt current.
Guess where he found the short. The element in the hot water service. Works on gas but not on power at the moment.
Funnily enough, when he first arrived and he gave me his thoughts he said it would be more than likely in the HWS but as that was the most difficult to get at, he would check the others first of all. On the way through the procedures he found a few loose wires and a couple on the way out that he replaced.
He is going to check on a price for the new element and let me know. He is a good bloke, efficient, on time and not a rip off merchant.
The van is seven years old and the HWS has had a lot of use in that time so I guess it has been a pretty good run.
Thanks for the advice once again.
-- Edited by DMaxer on Tuesday 3rd of March 2020 12:38:07 PM
Hey BigD, you tryin to blow yaself up mate confusehmmsmile
Just fooling around with a bit of 240 volt and some gas Doug. What could possibly go wrong?
Not much!
BOOM?
Needed - a box of suitable dimensions to put a body in?
Hope the party goes well, D-Maxer. My mother-in-law's 100th birthday attracted 97mm of rain recently in Toowoomba. Was ok if one stayed under the awnings - where they joined, you got wet!
My latest disaster has now been fixed. It turned out to be the element in the Dometic HWS. The electrician pulled out the element and you could see the rust around the bottom. It had been in there for seven years and has seen a stack of work since I owned the van over the last four years so I think I have had a pretty good run. I reckon I would spend nine months of every year in the van and during all those trips the HWS is switched on and stays on.
When I had spoken with a few caravan repair places that do this type of work I was given these horror stories about how long and complicated the procedure was and how expensive. The electrician ordered in a new element which cost a bit over $300. He drained the tank, removed old one and installed new one, filled tank and away it went. all done in less than an hour. Labour charge was $80 so all up $400. I had been quoted more than double that at a few places.
I hope this one last for another seven years. Now, on to my next disaster (I hope not). It's a shame this bloke doesn't make curtains.
Thanks for your replies and assistance.
-- Edited by DMaxer on Friday 13th of March 2020 08:50:18 AM
What brand of hot water system do you have ?
Most likely it is a Suburban.
If it is you got ripped off big time with the element cost.
www.caravansplus.com.au/suburban-240v-element-suit-sw6dea-sw5ea-sw4dea-water-heaters-p-6849.html
Bill B
No Bill. As stated in my opening line it is a Dometic HWS. If it was a Suburban HWS I would have said that.
I checked the prices online and with Truma and that was the correct price.
Always good to read a post before telling people they have been dudded. I think.
-- Edited by DMaxer on Friday 13th of March 2020 10:41:05 AM
Dmaxer I had never heard of a Dometic HWS, but on doing some research it is what used to be known as an Attwood HWS.
Our 2017 van has the same HWS however it is branded Attwood.
Bill B
I don't know about that Bill. My van is a 2012 model and the HWS is branded as a Dometic. It is on the plate. When I researched it on the last issue I was referred to Truma.Truma and Dometic are one and the same it seems.
Anyway, I was not ripped off and didn't really appreciate your ill informed reckless  comments when I was only trying to inform other members as to what was a reasonable cost should the same problem be experienced by them.
Perhaps we just leave it at that.
